Heater is not hot.
on
Your signature shows an 07. If that is the case, there is a good chance that the thermostat needs replacing. Both the water pump and thermostat are plastic and tend to crack over time, which creates a leak. The resevoir also can crack over time. Like stated above, see if your resevoir is low. If it is, top it off with the proper BMW/MINI blue coolant and distilled water.
If it is not low in the resevoir, there is a good chance that the thermostat has malfunctioned and would need to be replaced.
Do you do your own maintenance? There are how-to articles on both the water pump and thermostat replacement.
Have fun,
Mike
Have fun,
Mike
+1 most likely low coolant due to a leak.
See here for the thermo housing or the expansion tank.
https://www.northamericanmotoring.co...8-no-heat.html
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
