Mystery Fluid and other questions???
So I have an 06 R53 and I recently replaced the power steering pump. I didn't connect the wire completely so the pump went out and I think the pressure from driving it home without it also caused all of the CHS 11F steering fluid to leak. When I propped the car up to service it and refill the fluid. I removed the front driver side (US) tire, to my surprise there was a burnt orange caramelish or similar color fluid also on the axel. It was very thick and I could tell where the PS fluid was and this was in a different spot. VERY different from PS fluid! What could it be? All my fluid levels that I can check in the engine bay are normal. Please help!
I bought the car used and it has an ALTA 17% pulley on it, where or what kind of belt do I need to get to change my belt out. I also want to change out my rear sway bar bushings and engine mounts. Any suggestions on those? I have a kind of squeal/squeak on startup that just happens as its starting or if I pull the clutch out too much before pressing the accelerator, what could that noise be from?
I love my mini! It is so much fun to drive! I get why there are so many fanatics! Have a great day! Thanks for your time!
Power steering fluid leaks are quite common on these cars, whenever we have a chance to, we will remove the factory crimp style clamps on the feed & return lines and install worm style clamps in their place to stop the leaks at those connections. The return line is also a culprit for leaks, as it has a hose crimp about half way through where it transitions from rubber to steel.
The squeak/squeal you hear on clutch engagement is the DMF howling, or "Chewbaka", which can be evidence of a failing DMF or a worn clutch being engaged in the cold. Valeo has a great conversion kit that will fix a dying clutch, as well as do away with the burden of a DMF.
As for a belt, we will run a 1379mm belt on cars that run a 15/17% reduction pulley.
Nick
Detroit Tuned
squawSkiBum
Tires, Wheels, & Brakes
26
03-18-2024 07:21 AM
08-25-2015 09:33 AM
08-19-2015 12:51 PM
08-19-2015 08:27 AM
