Noise when cornering
Having some issues diagnosing a noise when cornering, it's rather strange. It's a 2009 Clubman with 140,000km on it (about 90,000miles I guess?).
The car sits over night in the driveway. When I start it in the morning, for about the first 5-10 minutes of driving, whenever I get into a right-hand bend, I hear a whirring noise (like "wub wub wub wub wub...") from what I think is the rear driver side wheel. Starts to occur as the body weight shifts to the wheels. Sounds almost like the wheel is rubbing on the plastic trim (no signs of wear on the trim). Noise seems to be proportional to wheel rotation speed.
The noise does not occur when turning/cornerning left. After about 5-10 minutes, the noise will no longer occur. Thought it might be brake related, but there is no drag and brakes seem to be fine. Wheel does not move if I raise the car and try to wiggle it. Spins freely.
Help would be much appreciated!
Thanks.
Was yours a repetitive noise? Mine also occurs only at slower speeds (then again, I don't take corners at high speed). It's not really a knocking noise, almost sounds more like a wobbling wheel or something (note: the alignment on the car is fine).
Can it be visually inspected? If I look under the car will I be able to see something worn out or anything?
Supertractor3
04-07-2017 11:16 AM
