Valve Specs Anyone?
Old 12-20-2014, 07:50 AM
jsf252's Avatar
jsf252
jsf252 is offline
Valve Specs Anyone?
Well my MCS started misfiring last week on #1 which led down a long path of determining the problem. After checking/replacing all of the obvious ignition/fuel items the problem still persisted. The engine was firing on all cylinders as proved by removing a plug wire and having the idle worsen, but something still wasn't right. This led to a compression test and finally a leak-down test. With #1 @ TDC air was leaking past the exhaust valves. The head is currently off and disassembled, and the problem seems to be pitted exhaust valves that were holding carbon deposits preventing the valves from completely closing. I'm currently in the process of lapping the valves, but I don't know if they are too far gone to save.
That brings me to a request from NAM members. Could someone give me the valve specs from the Bentley manual? A picture or a scan would be great. I need to get this head back together ASAP, and I don't have time/money to wait for the Bentley manual to ship. If anyone could help I would be most appreciative.
Thanks,
Josh
Old 12-20-2014, 02:43 PM
mrbean's Avatar
mrbean
mrbean is offline
What specs do you need? Seat angles?
Since everything is apart, you'd be best off just replacing the valves and lapping the seats.
See attached file for seat specs.
File Type: pdf
Old 12-21-2014, 07:14 AM
jsf252's Avatar
jsf252
jsf252 is offline
MrBean, thanks for the info. I managed to find those specs on the Bentley website, but that's all they provided. I wanted to know the installed valve height (from he tip of the valve stem to the a location on the head). As I grind the valves the stems move upward and I want to make sure that they are still within spec. As it stands my valve seats are getting close to the maximum and I can't really grind much.
This is what I'm looking for:
http://www.kmotion.biz/images/Installed.jpg
Thanks again for the help,
Josh
Old 12-22-2014, 05:41 AM
mrbean's Avatar
mrbean
mrbean is offline
Sorry, my manual doesn't have that info.
Old 12-22-2014, 01:46 PM
David.R53's Avatar
David.R53
David.R53 is offline
These are the most detailed specs I have found. The Bentley includes very little on engine internals.
http://www.bmw-planet.com/lib/mini/ENGINE%20TECH.pdf
Old 12-23-2014, 06:15 AM
jsf252's Avatar
jsf252
jsf252 is offline
Thanks MrBean and David.R53 for the info.
Old 11-11-2015, 09:19 PM
sparkyj's Avatar
sparkyj
sparkyj is offline
Did you ever figure out what the stock distance of the exhaust valve should be? From the tip of the valve to the spring perch area or top of the stock valve guide? I'm also installing new valves. I can see the new ones are a wee tad shorter than the original pitted valves. Which makes sense if the old original valve moved "up" over time as the base wore out...
Old 11-11-2015, 10:11 PM
sparkyj's Avatar
sparkyj
sparkyj is offline
.oops double post
SneedSpeed
09-21-2015 06:06 AM
hydouken
09-15-2015 05:49 AM
Accessory Products
09-11-2015 08:01 AM
09-02-2015 09:05 AM
cw40342
09-02-2015 06:01 AM
Quick Reply: Valve Specs Anyone?
