LIGHTS, IDIOT LIGHTS - Any one?
I own a 2009 Clubman with appx 65K on it. Car has been serviced regularly - was in for service in August. The light on the tachometer has been coming off intermittently when I start it - the yellow one that tells that there is an exterior bulb is burned out. I've done the 360 check, no lights burned out, generally it goes off a couple minutes after driving.
New problem yesterday - was driving at normal speeds, the radio quit, the readout with station went blank and every idiot light went on and the speedometer conked out. This lasted for about ten seconds, no loss of power, but then everything went back to normal. The little red light with the car on the lift came on briefly then disappeared - low tire pressure light came on as did engine light (yellow) the (!) light - all of them. Again, this all cleared within a couple of seconds - the engine was running fine - I was excelerating to get on the interstate -and had no problem.
Drove the car the rest of the day without a problem no more lights.
Has anyone had this issue occur?
Thanks!
Thanks!
Also check the electrical cables are attached to the battery properly and again check the battery for voltage. If bad , replace. Battery is located under the plastic cowl on the passenger side. , It has a small access panel to look at it. But to change it the whole plastic panel comes off.
#3 Apron Firewall Cover - Passenger Side ( Right ) 51132751210
http://www.ecstuning.com/Search/SiteSearch/51132751210/
Thanks and good luck.
09-28-2021 01:16 PM
08-21-2015 12:58 PM
08-21-2015 12:58 PM
08-21-2015 12:50 PM
08-19-2015 12:51 PM
