Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
I agree with SaltySalt. It's common, and if it's on the front right, it will be crank position sensor. If it's on the front left, it will be harmonic balancer/crank shaft seal.
actually option 1 is very easy and super DIY, the motor mount oil is a thicker black, and if you pop the hood, youll see it spread all over the crash bar next to the mount
I agree with suggestions that it is probably the engine mount (thick black goo) or the crankshaft position sensor seal (normal oil).
Here is diagram of what the engine mount (#3) on passenger side looks like:
Here is diagram of where the crank position sensor (#8) is located:
Clean the engine well and then look for the leak. Many people (including Mini Techs) have changed the oil pan gasket trying to resolve an oil leak when the leak was actually coming from the crank position sensor.
Check the oil filter housing and cooler. Sometimes leaks from the oil cooler attached to the filter housing can appear to be more like oil than coolant by the time it reaches the garage floor.
