Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
hello
The windows still have a problem even after raising a "manual" reset
after reading the forum the solution is to do a reset at the dealership
Before doing so I was wondering if this was possible via NCS Expert? and if so how?
In advance thank 's
Fred
bonjour
merci pour ton aide
1) quand je remonte les vitres elle descendent de 5 cm une fois arrivées en haut.
2) quand on ouvre la porte la vitre devrait descendre un peu pour se décoller et elle ne bouge pas !!
il me semble que le paramétrage a disparu
encore merci
fred
hello =>>> excuse me i answer in french ...
thank you for your help
1) when I go back windows it get 5 cm once they reach the top.
2) When you open the door the glass should come down a bit to take off and it does not move !!
If you have NCS expert, then you may also have INPA.
INPA can perform the same reset as the Mini dealership.
If you cannot use INPA, the go to the dealership for a reset.
