cooling fan replacement; IDIOT ALERT!!
Replacing your cooling fan? Don't do this! I inserted the wrong length bolt into the flange that holds the tranny cooler to the radiator, tightened it up and POKED A HOLE IN THE RAD! It was the bolt for the rad fan connector to body. Would have been better to send it to the shop. Oh, Well. Now I'm looking for a creative fix for the hole.
Just kidding, I had to say it! All joking aside that is a real bummer and I hope you get it fixed/replaced without any more issues.
Hope you got it fixed...
But only a $100 fix if you looked around....rockauto.com has exact fit copies of the OEM...same ones you would get at auto zone, etc...just MUCH cheaper....
Next time go slow....lol...ratchets can be better than power tools cause they give the home mechanic time to look for mistakes!!
Look at it this way....you needed to change the coolant anyway...and the radiator was old!! Sucks...but there is a bright side!!
Ha! Good one! I can't even use that as an excuse; My Corvair is a waterpumper!
Colt45Magnus
08-12-2015 06:43 AM
