Speed Sensor
Speed Sensor
06 MCS JCW...
So after having the EML, Tire monitor, and Traction control lights come on (in addition to my car going into "limp mode" [what a garage calls it], ie unable to accelerate) whenever I hit a substantial bump (this all started after hitting some nasty potholes on NYC highway). I decided to replace the speed/ABS sensor on the driver's front (where I thought hit the holes the hardest). *I should add, if I flick the ignition off, everything's fine until the next bump.
NOW I have the ABS, Tire, and Traction lights coming on, in addition to the EML when I hit a jarring bump (and limp mode).
I've unplugged the sensor I just replaced, a couple times, but those dang lights still appear.
Any suggestions?
Any suggestions?
Vendor
You've got something other than the wheel speed sensor bad. Get the codes read for the ABS and go from there.
If you need a tool to read the codes the Easy Diag tool is cheap and can read them.
Remember....
Limp mode occurs when the ecu sees something (like a sensor reading out of limits, either cause the sensor is broken or a part has failed) and basicly says "I can't go on" and goes to limp mode...kinda like a safe mode on a computer.... Let's you get to the side of the road....
Restarting the car temporarily clears everything...letting you drive...till the bad reading is seen again. I'd bet 99% that you wheel speed sensors have nothing to do with it...just don't think that system can interact with the ecu in that way....good luck!!
I have had 2 go out and nothing other that the 3 lights coming on in the dash.
07-16-2020 12:54 PM
Marktheman
08-23-2015 11:45 AM
