rough idle and P1497 code!!
Hi,
My 08 clubman S threw a code this morning. It was P1497 from auto shop code reader. And I have rough idle from time to time. After I searched forum, I think I have cracked cylinder head cover problem. I hear vacuum leak around pcv valve location. But I can not believe this plastic cover just broke down. Everything is consumable part in this mini.
* MINI DTC P1497 (0x2B64) - Downstream Throttle Air Leak
It's becoming more prevalent due to the possible internal PCV valve being blocked / clogged in the valve cover.
The pressures overload the seals and integrity of the cover and create leaks.
Valve covers are cheap and easy to replace.
- Erik
- Erik
I recently purchased an R56 and after cleaning the MAF and clearing other codes I have this code and the leaking sound from the same area. Thanks for the info provided!
If you fretting over a part that's only some 1%-2% of the total vehicle cost, you're owning the wrong vehicle.
- Erik
http://www.detroittuned.com/mini-coo...4-valve-cover/
Nick
Detroit Tuned
NHcountryman
09-06-2015 11:01 PM
