roll call, have you replaced your thermostat housing .
#426
#427
I replaced my thermostat housing because it was leaking. I had to find out where the leak was. So I plugged up all six hose connections on the old housing and drilled a steel plate to cover the block connection and allow an air line connection. Ran 20 pounds of air pressure. The entire assembly was put underwater in a laundry tub. I was surprised that the leak was not one of the seams but a very small pin hole or crack in the housing. The arrow in the picture points to the general area. The leak was actually in the corner. Again, I was surprised that my housing did not leak where they were joined together. Anyone else pressure test their housing?
#430
#431
When I bought the vert with 46k I put it in front end service to replace the crank sensor O-ring that was leaking. As I had it apart I then also replaced the water pump, tstat and stat housing. The tstat you can do without service mode, the pump you cannot.
You can buy a housing with a tstat for less than $20.00 (and also pay a whole lot more if you want). There are threads here about a metal housing vs a plastic. At the end of the day it comes down to what you want to do with your car.
#432
Is it always advised to replace the housing with the thermostat? I've done some reading and see a few people saying that it is a good idea to replace both while I am in there. Any other thoughts? I don't see any leak, so I can't see a reason why I should replace it now.
#433
The t-stat is a separate piece that fits inside a clear plastic gasket that in turn mates to the housing on the Gen 1, I don't know on Gen 2 but it would seem odd that tstat is cast into the housing and not a separate piece.
#434
Happen to have a link to one? I'd like to replace it while I have my thermostat housing off.
#435
Do you have links to this <$20 housing with tstat and the metal housing? I've never seen a metal option, but I'd replace the cheap plastic with metal in a heartbeat if it were an option.
#436
2009 Mini Cooper bought second hand last November. 70000 kms. Replaced thermostat housing myself (It already had been repaired with some liquid gasket messy thing). Then took it to dealer as it developed another leaks: water pipe, water pump and oil filter housing gasket (again same liquid gasket previous repair...), 800€ so far... I still wonder why this engine (N12) works so high on temp, around 102ºC...
#440
Is the recent water pump leak lawsuit settlement by chance include thermostat leak?
my water pump was leaking coolant so I took it to the dealership. I found out there was this lawsuit settlement about the water pump leaking so they agreed to fix it for free. However they then told me there is another leak on the thermostat. I know nothing about mechanics but does anyone had similar issue? Is the thermostat leak related to the water pump or could it be possible the settlement include the thermostat? Thanks!
#441
#444
#445
#446
135,xxx miles on my 09 FJCW. just replaced the t-stat housing with a part from ebay that i was told was a gates(arrived in a brown unlabeled box)and a genuine mini water pipe. the end of the water pipe crumbled into pieces when pulled out, and the housing was leaking at a seam. after replacement, i have an intermittent code for coolant temp out of range, hard starting sometimes, and 2 body codes i cant identify. other times, runs ok. im going to put the old coolant temp sensor back into the new housing this weekend and see if that fixes this issue.....
#447
We have ones listed a couple pages back. My guess its maybe not gates. We had no issues with what we sell. Had a hand full of ones over the many years sold that the temp sensor was bad from the factory but we just sent out a new one and it fixed it. If if does not fix it make sure you bleed the system good, if the coolant makes an air pocket at the top the fluid coolant will not touch the sensor all the time and it will through a temp out of range code. I bled mine like 3 times cool to warm to get all the air out. Use a long skinny flathead screwdriver on that top bled screw and dont back it out all the way, it can pop off easy and fall into the engine bay. Good luck.
#448
120~K and still haven't replaced mine. The housing and gasket are great, I did replace my t-stat and coolant temp sensor since I was in there. Still have them as spares if I'm in a pinch.
FYI: Don't try to save a buck on these, you get what you pay for. I received a completely dead coolant temp sensor trying to save $10 (seller to remain anonymous). Trust me on this. Ya get what ya pay for! ;]
#449
