timing chain, timing tensioner Recall effect 500,000 Mini's
Old 06-07-2013, 02:01 AM
nrfitchett4's Avatar
nrfitchett4
nrfitchett4 is offline
The link provided is when removing the timing chain for replacement, not sure if it's used for checking chain slack.
Does anyone know if your supposed to pay the deductible for your warranty (6-year/100k) before or after the warranty work is completed? Carmax warranty
Shouldn't have to pay until work is complete. You have to authorize the tear down to diagnose the problem. For the timing I was quoted 179. You are only responsible for that if the repair is not covered by the warranty. Otherwise, you just pay the deductible. The warranty pays the shop the total amount minus the deductible, which you will have to pay to get the car back.
  #252
Old 07-23-2013, 06:53 PM
john171's Avatar
john171
john171 is offline
Originally Posted by petrojo
Hi members--I've seen no discussion of timing shifts from tensioner failure on this board, and as I say, the car ran fine but for the rattle, so is this BS? thanks!
If the chain did jump it most likely did affect the timing, might not be enough to notice while driving, but if not fixed it can lead to extensive, and expensive damage to valves, pistons etc. Don't know your dealer but if you feel uncomfortable there go to an independent shop, just be aware that driving the car with the timing off is risky at best.
Our MINI just flashed the yellow engine icon yesterday, when I got home checked for codes and P1497 showed up = Downstream throttle air leak. So it's going into our indie shop shop tomorrow. Checked all hoses and for any obvious leaks around the engine bay, no luck. BTW one of the potential problems associated is the death rattle, in a round about away....Will keep posted.
  #253
Old 07-23-2013, 07:01 PM
Velocityvic's Avatar
Velocityvic
Velocityvic is offline
If the chain has stretched enough to jump get it in for service! Do not pass go! Do not collect $200. You can trash the whole motor if you don't take care of it now. Usually not a ring jump. Mine barely made any noise at all but I was suspicious. Once inside I had a broken guide rail!
  #254
Velocityvic
Timing jump, sorry.
  #255
Old 07-28-2013, 05:11 PM
scubbysnacks's Avatar
scubbysnacks
scubbysnacks is offline
One thing no ones mentioned is flushing the engine with an additive before draining the oil during an oil and filter
change, I did and was surprised how black the oil was and the crap they came out with it. This was after 10,000km, I'm switching to 5,000km flushes,oil and filter changes.
  #256
Old 07-28-2013, 05:24 PM
john171's Avatar
john171
john171 is offline
What did you use, and what steps did you take...in other words...a DIY guide...
  #257
Old 07-28-2013, 05:40 PM
john171's Avatar
john171
john171 is offline
UPDATE on the Yellow Engine light
The tech at the shop gave it the once over and could not find any leak visually or by sound, so they did the smoke test and eureka, found two O rings in the OCC tubing that were gouged, mea culpa! He replaced them and solved the vacuum side problem, there was a slight leak where the output side from the engine heads to the OCC, the pressure side of the link, due to the connector having slipped out part way, it appears a clip was missing, which BTW was missing from new - (item 16 in the attached diagram)...so that took care of the air leak...the noise I was hearing that I thought was the death rattle was just normal engine noise, he checked the tensioner and it was OK...
Attached Thumbnails timing chain, timing tensioner Recall effect 500,000 Mini's-390-copy.jpg
  #258
Old 07-28-2013, 05:54 PM
danjreed's Avatar
danjreed
danjreed is offline
Just so you know... We call'em wallet flushes in the industry..
Your better off not doing them.. Just use proper quality synth oil and change it at 8km.
Oils job *is to turn black*...
  #259
Old 07-28-2013, 05:55 PM
scubbysnacks
Basically just a normal oil change but before you change the oil get the car up to temp pour in additive where you top up the oil through the valve cover(I used liquid molly engine detox) and run at idle for approx 10min let oil cool so you don't burn yourself then continue oil change as normal.
  #260
Old 07-28-2013, 06:11 PM
DOC4444's Avatar
DOC4444
DOC4444 is offline
The tensioner does not "fail" and therefore does not need to be "checked". The slack is what needs to be measured. When the timing chain slack exceeds the travel of the tensioner, teeth are skipped, leading to piston/valve contact. The "new" tensioner is just a little longer. The design is the same. It can control a little more slack, that's all.
DOC
  #261
Old 07-28-2013, 06:44 PM
gregsmini's Avatar
gregsmini
gregsmini is offline
DOC
That's an interesting statement. I replaced my second tensioner after about 30,000 miles. The plunger did not push in smoothly. When pressure was applied to the plunger, it would go in a small distance and stop until more tension was applied then it would suddenly move in again, stop, add more tension, then go in abruptly again. After replacing it, everything is fine. Not sure you want to describe that as "fail" but it certainly wasn't working as designed.
  #262
Old 07-28-2013, 07:12 PM
DOC4444's Avatar
DOC4444
DOC4444 is offline
Interesting. First I have heard about the tensioner "sticking" in its travel. Did you measure your chain slack or simply replace the tensioner? What tipped you off to this and what was different after you replaced it. What were your oil change intervals?
Thanks,
DC
  #263
Old 07-28-2013, 07:43 PM
Velocityvic
The original tensioner gets lose or actually the bolt that holds it in place which can cause the chain to stretch, etc.
  #264
Old 07-28-2013, 08:01 PM
john171's Avatar
john171
john171 is offline
DOC
Pulled it and checked for good play in the spring - , and unusually heavy or uneven wear - , none was found, all's well that ends well, at least for now.
And I do oil/filter change every 4500 - 5000 miles, Castrol full Synth 5-40, at which time I also rotate my tyres....
  #265
Old 07-29-2013, 03:41 AM
gregsmini's Avatar
gregsmini
Thanks,
DC
I heard the chain rattle, and no, I did not measure the chain length. As you can see, I bought my MINI new. I did an initial oil change @ 1,800 miles and have changed the oil and filter every 6-7,000 miles. I do want to do the complete chain assembly replacement soon. I have a bit more than 68,000 miles on the car and it is running fine.
  #266
Old 08-01-2013, 08:12 AM
mymini09's Avatar
mymini09
mymini09 is offline
09 Clubman S-Turbo Out-Under 45,000 miles
I own a 2009 Mini Cooper Clubman S that has under 50,000 miles on it. Back in February, 2013 the tensioner, timing chain and Turbo all went out!!! Less than 45,000 miles! I was less than 2 weeks out of warranty and Mini refused to cover the $4000 in repairs! I left my car at dealer for over two weeks while I argued with Mini to back up their product. They finally agreed to pay for half! I decided to go back and look at my car fax from when I bought the car and found out this was the 2nd timing chain it has had replaced! I feel like Mini should have covered this 100% and now I am trying to find someone that might know if there is a Class Act Lawsuit on this yet? If not, does anyone know how I would get something like this started? I did research online for weeks and found these issues all over the place in these cars! Something needs to be done! At this point, I am going to lose money on this car because of the repairs I've had to pay for in the 10 months that I've had it! I am also worried it will happen again and Mini told me on the last one that they will not help me on any other issues on my car. If this happens again, I DO NOT have $4000 laying around. I am a single working mother and I shouldn't have to worry about this type of thing with a vehicle. In all my experience in owning high end vehicles and high performance cars, I have never had this happen! Anyone have any thoughts or suggestions please share with me?????
  #267
Old 08-01-2013, 08:19 AM
RobMuntean's Avatar
RobMuntean
RobMuntean is offline
I would trade the car in ASAP for something different. It's not worth it, that's one of the reasons I held back on a 07-10 R56. But at least they're helping you by paying half. They're greedy bastards. Hope it ends well and you get rid of this lemon you have right now.
  #268
Old 08-03-2013, 08:59 PM
boOst spIKe's Avatar
boOst spIKe
boOst spIKe is offline
Sit tight ladies and gents (N14 owners) a solution and resolve is in the works. Don't quote me, but a little birdie told me BMW/MINIUSA is involved and will make headlines in this thread.
  #269
Old 08-03-2013, 09:22 PM
Agbullet25's Avatar
Agbullet25
Agbullet25 is offline
Is there an estimate on timeframe before we hear something?
  #270
Old 08-06-2013, 11:14 AM
liveepic's Avatar
liveepic
liveepic is offline
EXTREMELY interested in that statement boOst spIKe, watching this thread closely...
  #271
Old 08-07-2013, 12:35 AM
nrfitchett4
heard the same thing last month. Will wait and see. I only had to pay 100 deductible for a full replacement, though I'm sure my 3rd party warranty would love to recoup the rest...
On a side note, did my first oil change and the day before I added half a can of seafoam I had laying around to the oil. Probably put 50-60 miles on it before changing the next day. Didn't really notice anything extra coming out of the drain. Curious if anyone has had any real world success using "cleaners" before changing the oil.
And for the single mom, one post person above: I agree you should probably trade your car in. This isn't the car for you if you are not somewhat mechanically inclined, have an extended warranty or have deep pockets.
There are many sites out there (consumer reports/ edmunds) that offer reliability scores on used cars. Might want to do some research on something more reliable. Also make sure you check your oil. Two failures in that short of time would make me think the oil is consistently low.
  #272
Old 08-09-2013, 09:28 PM
SoundMessage's Avatar
SoundMessage
SoundMessage is offline
  #273
Old 08-10-2013, 07:45 AM
TREX's Avatar
TREX
TREX is offline
You might want to check out the Edmonds site before referencing it as a good site to look at Mini Coopers reliability.
http://www.edmunds.com/mini/cooper/2...liability.html
Given the known history of timing chain failures, I don't know how Edmonds could give the Mini an absolute five star rating for reliability but the do.
Having done my research, I knew enough not to buy a Mini without it being covered with a warranty but unfortunately a very large percentage of potential Mini buyers out there will not take the time to perform a proper research of this cars reliability history, which is not contained on sites such as Edmonds, but rather found through searching through forums such as this one and even then you have to dig deep becuase it is very natural for enthusiast forums to try and protect/deny/hide negative postings about thier favored Mini Cooper.
Of course they (the forum members) do no favor to unsuspecting prospective buyers, such as the lady mentioned in the above posting, who may come here to this forum looking for honest answers about the good and the bad about these cars before purchasing one and recieve only the good.
I, for one, can appreciate the candid responce above about "buyer be ware" if not mechanicaly inclined, under warranty or very deep pockets before considering purchasing one of the "S" series Mini's due to such issues as timing chain failures and carbon build up.
  #274
Old 08-10-2013, 10:10 AM
Slave to Felines's Avatar
Slave to Felines
Slave to Felines is offline
Originally Posted by TREX
... searching through forums such as this one and even then you have to dig deep becuase it is very natural for enthusiast forums to try and protect/deny/hide negative postings about thier favored Mini Cooper.
Have you even read this forum? When something like a quarter of the posts in this section of the BBS talk about the timing chain problems in one form or another, I find it hard to see how you can accuse anyone of trying to hide negative postings...
  #275
Old 08-10-2013, 10:19 AM
Agbullet25's Avatar
Agbullet25
I think he's talking about enthusiast forums in general, not singling out NAM in particular.
Quick Reply: timing chain, timing tensioner Recall effect 500,000 Mini's
