Gen 2 Technical Service Bulletins (TSB) Database
Old 05-26-2011, 06:19 PM
fishbert's Avatar
fishbert
fishbert is offline
Originally Posted by TheCheatOSX
This probably isn't all of them, only the ones I've discovered. If anyone has a SIM number from an invoice, etc. not on the list let me know.
Still looking for a sticky.
SIM 120509 might be an interesting document to read, if you can dig it up.
  #27
Old 05-27-2011, 08:52 AM
TheCheatOSX's Avatar
TheCheatOSX
TheCheatOSX is offline
I've dug around and can't seem to find that one. Strange.
  #28
Old 06-12-2011, 09:08 AM
djbrown's Avatar
djbrown
djbrown is offline
This is great!!! How do you vote to add for sticky status?
  #29
Old 07-01-2011, 06:22 AM
rum4's Avatar
rum4
rum4 is offline
I vote for sticky also
  #30
Old 07-01-2011, 09:55 AM
fishbert's Avatar
fishbert
fishbert is offline
You two are adorable.
  #31
Old 08-24-2011, 03:29 PM
SD4US's Avatar
SD4US
SD4US is offline
That is some great info!
However, the ZIP file seems to be no longer available for download.
It says file/link is invalid or deleted - or something like that.
Would it be possible to upload it again?
Thanks!
  #32
Old 09-06-2011, 01:57 PM
TheCheatOSX
I'm not sure where the Zip went. I reuploaded it and updated the OP with the current URL: http://www.mediafire.com/?fwft6t68zwlqa04
  #33
Old 09-06-2011, 03:26 PM
RJKimbell's Avatar
RJKimbell
RJKimbell is offline
Update 9/08
Anyone know of a TSB on O2 Sensors?? Molly is staying the night @ MINI of Portland and their opening up a PUMA Case, this is the 4th CEL for a P013A.
UPDATE:
MoP found the Gasket from the Catalytic Converter to the Exhaust (muffler end) leaking, R&R Gasket, Test Drove her 50mi. rechecked the faults, no codes stored.
Cudos to Jarid, he always handles all of my concerns as valid, and always takes such good care of Molly!!
  #34
Old 09-07-2011, 09:50 AM
fishbert's Avatar
fishbert
fishbert is offline
anyone have SIM 120210? supposedly it has to do with using the new BMW Group Carbon Blaster to shoot walnut shells into your intake ports and clean of carbon buildup.
  #35
Old 09-07-2011, 11:14 AM
TheCheatOSX
Good SIM find! I've been looking for this info for awhile.
SIM120210 Cooper S with N14 – Diagnosis for Misfire Faults
SIM120210 N14 Direct Injection & Combustion Chamber Cleaning Procedure attachment
I updated the Google doc spreadsheet and the zip archive.
  #36
Old 09-07-2011, 12:24 PM
fishbert's Avatar
fishbert
fishbert is offline
Wow...
"Additionally, MINI USA recommends that this service [fuel injector cleaning] be performed yearly (on a customer-pay basis) on N14 vehicles which currently do not exhibit the negative harmful effects of carbon build-up, to maintain MINI’s dynamic performance and maximize fuel economy."
EDIT: ah, thought it was referring to the walnut blasting... "just" injector cleaning. I actually don't see anything about the carbon blaster in either of those.
  #37
Old 09-07-2011, 01:08 PM
RJKimbell's Avatar
RJKimbell
My SA was just talking about the Walnut Shells yesterday, I was asking him about an "S" Auto and he said this service should be done around 60,000 mi. and that they use Walnut Shells, the Walnut Shells will burn up as opposed to 'Sandblasting' the parts clean.
  #38
Old 09-13-2011, 08:03 AM
jaridp's Avatar
jaridp
jaridp is offline
Originally Posted by rjkimbell
cudos to jarid, he always handles all of my concerns as valid, and always takes such good care of molly!!
thanks julie!!
  #39
Old 04-05-2012, 12:39 PM
pmsummer's Avatar
pmsummer
pmsummer is offline
Thanks! I just acquired my 2009 R55 w/21K on the odometer. This should help me plot my strategy over the next 12 months, before the extended warranty kicks in.
Forewarned is forearmed!
  #40
Old 02-22-2013, 07:19 PM
cumang0's Avatar
cumang0
cumang0 is offline
hello, new to the forum but found this sticky to be extremely useful.
had SIM330107 (knocking from sway bar bushes) issue confirmed.
Thank you!
  #41
Old 02-23-2013, 09:00 AM
BlackIce's Avatar
BlackIce
BlackIce is offline
Thank you!
DITTO! THANK YOU FISHBERT Have a clunk coming from the rear when corning now and then. Wonder if this is the issue???
  #42
Old 02-23-2013, 09:10 AM
pmsummer's Avatar
pmsummer
pmsummer is offline
Thank you!
The similar (but different) 330110 is one more-last thing I'll have the dealer look at before the warranty goes away next month.
  #43
Old 02-23-2013, 11:04 AM
cumang0's Avatar
cumang0
cumang0 is offline
i hope that isn't the issue for me...out of warranty, looks like a big job for a DIYer and will take longer than usual for a mechanic to work on (meaning higher cost)......*fingers crossed*
hopefully it's 330107; if it is i may upgrade to energy bushings and a larger rear sway bar to improve cornering. it's a shame the MCS RSB is only 1-2mm larger in diameter compared to the Justa's and One's.. (I have a UK Mini One) ..won't have an affordable OEM upgrade like I did when I had an Accord sedan and upgraded to the Acura TL Type-S RSB....it was basically a "goodbye to understeer". anyway, just rambling at this point hope all of you guys have your issues sorted. best of luck.
  #44
Old 02-23-2013, 08:10 PM
Slave to Felines's Avatar
Slave to Felines
Slave to Felines is offline
Since the spring force for a torsion bar goes up with the 4th power of the diameter, a change of 1-2mm can actually be pretty substantial. E.g., 22mm ^4 = 234256, 24mm ^4 = 331776, 1.4 times as stiff!
  #45
Old 02-23-2013, 08:12 PM
cumang0's Avatar
cumang0
cumang0 is offline
okay, you got me looking for sport suspension MCS RSBs on eBay now. >:(
  #46
Old 03-29-2013, 02:42 PM
surfin'02's Avatar
surfin'02
surfin'02 is offline
This is awesome!!
Thanks very much!!
  #47
Old 05-23-2013, 11:30 AM
trakatdave's Avatar
trakatdave
trakatdave is offline
I had a 2 year service on a 2011 MCS Clubman today and they completed 4 SIM,s. They are M11 05 12 Replace timing chain tensioner, M17 08 12 Coolant temp sensor campaign, M17 08 12 Door sill trim campaign, M51 01 13 Replace sun visors campaign.
  #48
Old 05-23-2013, 11:45 AM
TheCheatOSX
Very interesting. I can't find those three yet but I am interested in the Sun Visors one as both of my visor mirror cover hinges have broken and they hardly ever get used.
  #49
Old 05-24-2013, 06:56 AM
trakatdave's Avatar
trakatdave
The dealer replaced both front sun-visors even though there was no problem the original set.
  #50
Old 05-31-2013, 09:30 AM
cnolan
cnolan is offline
Will they do these SIMs outside warranty?
Quick Reply: Gen 2 Technical Service Bulletins (TSB) Database
