dead battery how to open trunk ?
No trunk on a MINI. Now the boot latch is all electric - so it most def will not open with a dead battery.
See last post here for where the cable release must be...
https://www.northamericanmotoring.co...k-release.html
02-S didn't have the cable release (or a jack)
if you don't have a battery charger just hook it up for jumping using the 'special' positive terminal under the bonnet aka jumper box; your electrics should now work
BUT you probably don't need a battery, you need a ps fan so a brute force solution is to leave the back seats down and disconnect the battery when you park the car until the primary problem is fixed.
Once you get it running do a hour or so at highway speed and your battery will come back if it wasn't too nearly toasted b4 this began. Back enuf for a start or two anyway ... once everything is fixed a good day or two of driving if you have an average commute should fully charge your battery - if it is a decent battery now.
OR
simply jump the car to start it, then drive to the battery place and open everything b4 you turn it off . . .
OR
Interior/Exterior Must see: Liberty Walk body kit for Mini Cooper R56
carid
09-02-2021 07:22 AM
UncDeo
11-04-2019 04:08 AM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
wildwestrider
09-06-2015 06:18 PM
