MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 07-30-2010, 09:12 AM
HRM's Avatar
HRM HRM is online now
Gallery
Why me? Valve cover nut disintigration
I never saw anything like this, the nuts (or I Guess actually bolts) are falling apart. It just goes to show, that luck counts.
Anyone ever heard of this before? I can tell you if ever there was a way to make an easy job hard, this will do it.
I am going to spend hours on something that should take 10 mins. lol
Woe is me.
9 out of 10 of the voices in my head are telling me to "floor it!"
Webb Head, RMW Cam, RMW tune *228HP/199TQ, 2 1/2" Alta Full exhaust, Koni FSD, IE fixed, Meth@ 10lbs., 450cc injectors, 15% pulley, ATI damper, M7 cc, MM OC, M7 STB, H&R 19mm RSB, Wilwood BBK, Koenig 16in rims, Firestone Indy 500s, boost, oil temp and pressure gauges, Hot Air Intake, Italian Air Horn
Old 07-30-2010, 09:20 AM
MINIdave's Avatar
MINIdave MINIdave is online now
Gallery
What do you mean by falling apart?
They're metal screws, how are they falling apart?
'09 LB/LB Clubman S
'69 Jaguar XK-E
'04 Audi Allroad Twin-Turbo
MMC#580
Let's Go Clubbin!
Old 07-30-2010, 09:30 AM
HRM's Avatar
Gallery
They are rusted to the point the are falling apart. The car itself isn't rusty, but in the northeast, they use salt and it is as if one day the car went through a salt puddle and the salt got up there and never left.
Just two in the middle front center, but they rusted so much they are round without any torque at all, it's just flaking and falling apart.
Old 07-30-2010, 09:46 AM
soccerbummer1104's Avatar
soccerbummer1104 soccerbummer1104 is offline
Send a message via AIM to soccerbummer1104
Gallery
just hop down to lowes and get one of the things used to back out stripped bolts, and hope for the best.
03 MCS b/w, checkered rear spoiler & rear view mirror caps, xenons, Katzkin custom leather/suede interior, alta 15%, lightbar (55watt hid), 19mm sway, cold air. 7.5J 17 BBS CV, WMW-> ATI SuperDamper Crank Pulley Powerflex tensioner bushings.
Old 07-30-2010, 12:54 PM
MINIdave's Avatar
Gallery
Wow, so it sounds like the heads are rusted off and there's nothing left to get a torX bit into?
See, just a little bit more info really helps us understand what you're going thru and how to help you....
Soccerbummer's suggestion is a good place to start. Failing that it sounds like you need to drill the heads off, then when you get the cover off the rest of the screw should be easy to get a hold off and back out.
These aren't torqed in there very hard, if you can find a set of reverse drill bits, sometimes the screw will back right out as you're drilling the heads off.
'09 LB/LB Clubman S
'69 Jaguar XK-E
MMC#580
Let's Go Clubbin!
Old 07-30-2010, 03:09 PM
HRM's Avatar
Gallery
Thanks for the good thoughts. It wasn't so much that I needed advice, it was just about how a 10 min job can go bad...much worse than I thought at first.
Getting it apart wasn't the worst of it. Various sized sockets and wrenches, a ball peen hammer, little lever (to get the bolts out of the socket) and lubricant did the trick. (Thank you John M [previous owner] for using anti-seize)
The bad part is waiting until Wednesday for the stupid bolts to get to mini. I thought they may stock them but I guess they don't work on older ones yet. I bet they will stock a set sooner or later. Only a couple are really bad, but I don't want to stick half assed bolts in to haunt me in the future. So, I will wait. I still get to ride over to mini, but not until next week.
So, it turns out a 10 minute job has turned into a five day marathon. I just wanted to B*tch to someone who might find it nice that for once it isn't them.
Old 07-30-2010, 03:18 PM
Speedwing's Avatar
Speedwing Speedwing is offline
Gallery
MINI bolts? Am I missing something?
http://www.mcmaster.com/ is where I would look for them and they have super fast shipping.
http://www.totallystainless.com/ is another option.
Bob
Speedwing
Motoring in HENDRX
2005 Purple Haze MC
Old 07-30-2010, 03:50 PM
HRM's Avatar
Gallery
Thanks speedwing, I actually get good prices from a semi local mini dealer. They are ordered up with a 30 second phone call and it isn't really too far (though I can't use the mini to get there).
I will file these sites for the future. Usually I try to order things like this at my leisure so I can save a buck. When I am pissed, I just pay the man.
PS, some are not just bolts, but are studs also used to mount things along the engine.
Old 07-30-2010, 04:46 PM
MINIdave's Avatar
Gallery
Don't those have a retaining clip to keep them attached to the valve cover?
'09 LB/LB Clubman S
'69 Jaguar XK-E
MMC#580
Let's Go Clubbin!
Old 07-30-2010, 07:38 PM
HRM's Avatar
Gallery
Quote:
Not that I saw, there were inserts for the cover, but they all came out.
Old 07-31-2010, 06:46 AM
zminitech's Avatar
zminitech zminitech is offline
Gallery
Two words....
Turbo Sockets.
R55 Front brakes FS, calipers/rotors/pads
Wood Steptronic shiftknob FS PM for further details.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
