MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post 09 JCW Clubbie
3 Replies, 107 Views
Go to first new post The Peerage of the Pepper...
by BoCRon
2,700 Replies, 238,680 Views
Go to first new post I'm New - I Scored!
12 Replies, 285 Views
Advertisement
Thread Tools Search this Thread
Old 07-29-2010, 06:55 AM
funR53 funR53 is offline
Gallery
HELP - I'm New to Mini - P0172 code
Hello All,
I am new to Mini so please bear with me. I purchased an 06 S with several modifications (they are listed below). The check engine light is on and throwing P0172 code. The Long Term Fuel Trim on Bank 1 is at -20% at idle and drops to about -10% at 3,000 RPMs.
The car runs great but I can't get it to pass emissions.
The car did not have a cat on it when I got it. I replaced both O2 sensors and put on new CAT.
Someone recommended replacing both MAP sensors? Is this the next logical step? Any other suggestions?
Thanks,
Scott
The MODS are:
Madness Water-toAir Intercooler
Madness 15% pulley
Madness Intake
Madness Cowl Intake
CHR Head
Madness 380cc Injectors
Schrick Cam
NGK iridium plugs
Nology Wires
MTH Tuner
Madness Header
Milltek exhaust
Old 07-29-2010, 08:52 AM
Helix13mini Helix13mini is offline
Vendor
Gallery
What cat did you put on the car, and how many miles ago?
Old 07-29-2010, 09:55 AM
AK.JCW's Avatar
AK.JCW AK.JCW is offline
Send a message via AIM to AK.JCW Send a message via Yahoo to AK.JCW
Gallery
Garage
Old 07-29-2010, 12:17 PM
JumpingJackFlash's Avatar
JumpingJackFlash JumpingJackFlash is offline
Send a message via ICQ to JumpingJackFlash Send a message via Yahoo to JumpingJackFlash
Gallery
Garage
Just a note on the P0172 code link. '02-'06 MINIs do not have a mass airflow (MAF) sensor. They have two MAP sensors that work together to determine the proper air/fuel mixture. This is also known as speed density.
You have an aftermarket header and aftermarket exhaust. Look to see if you have an exhaust leak. This can cause false codes with the O2 sensors. Definitely check for vacuum leaks around the engine as well. Get a piece of hose and hold one end to your ear. Listen for a distinct hissing sound.
Another thought that comes to mind is you could possibly have a problem with your high-pressure fuel pump. Testing will require a mechanic's diagnostic.
'06 MCS, AB/DS, #1/#2/#3, RMW Tuned, 15%, DDM CAI, GP IC w/DDM GP div., DT BPV, Brisk silver plugs, Invidia exh., M7 Ext. Scoop, GReddy AFR/boost gauges, M7/Cobalt F/R st. bars, H&R 25mm comp. R swaybar, BBS RK rims, Kicker speakers/amp/sub, Rock-Fos 1F cap, Westin driving lights, Angel Eyes lights, Gear Jammin' LED tail lights
http://www.cybertekit.net/mini/signature2.jpg
Old 07-30-2010, 02:33 PM
Gallery
Thank you for the advice. I am on the hunt. Did find that the rear O2 wiring was touching the heat shield. Fix that now the light is out. Fingers are crossed. I'll report back. Thanks.
Old 07-31-2010, 06:54 AM
zminitech's Avatar
zminitech zminitech is offline
Gallery
You'll have to check your intake for leaks using a smoke tester, most likely cause is the plastic charge pipe from the throttle to the supercharger.
R55 Front brakes FS, calipers/rotors/pads
Wood Steptronic shiftknob FS PM for further details.
Old 08-04-2010, 07:26 AM
Gallery
Garage
Yes, a smoke tester works too. I forgot about that. I should see about buying one for future use myself.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
