P0705 Transmission Range Sensor
2004 MC Automatic
I'm new to the mini experience and the first 1 1/2 weeks have been quite an experience! I thought the power steering pump was out but was lucky in that it was just the electrical connection was loose. I now have a service engine soon light. I went to Autozone to pull any codes: P0705 Transmission Range Sensor. The transmission seems to be working fine. Any suggestions?
thanks for the help
Will
thanks for the help
Will
p0705
i am having the same issue. with my 2006 r52 ECVT. transmission. the parts guy at the dealer said it could be theStart inhibit switchpart #24357518731.but i think before i replace it i will clean the connector on the sensor of the transmission and the under the shift lever inside the car.
i am also getting a P0301 P0300 and P0313 not sure if they are all related. or separate
also i will get the CVT transmission oil change. Transmission shop recommend every 50k miles.
http://www.realoem.com/bmw/enUS/show...diagId=24_1007
07-16-2020 12:54 PM
