Ive searched around but couldnt find anything that could really help (03S manual). It seemed to have started with squeeking when shifting gear to gear. It then changed to hard shifting from gear to gear, basically having to pull into gear. It doesnt matter if the car is on or off. When the car is off, even without pushing in the clutch, it still is hard to shift (and still squeeks). Any ideas?
03MCS, ENKEI RSV 17", ALTA 15% pulley, ALTA CAI, OPTIMA yellow top, NGK iridium plugs, NOLOGY Hotwires, RACING DYNAMICS strut bar, Chameleon Viper Stripes, Color matched (BRG, BLK) dash/door cards (with dash Viper stripes), Flush fiberglass rear amp rack, Kenwood HU, ROCKFORD FOSGATE (old school models, pre 99) Punch 400, Punch 200 amps
Your problem is probably due to water/dirt in the shift cassett. If you are in a cold climate, look forward to being unable to shift on first start in the AM until the car warms up enough to melt the ice in the shift cassett. I hope to look at this on my 03 S before winter, but that was also last year's plan
What about the Clutch Slave Cylinder? I've replaced mine once in the summer and will have to replace it again this week. When it leaks it's hard to shift until it won't shift at all. Look under the front of the MINI near the driver's tire. Is there fluid?
I'm looking for a thread on this. I've found a few, but looking for more on a continual problem with the CSC and if there's something that can be done.
dude i had the same problem m yuncle is a mini tech in canada i gave him a call and he told me to pull the airbox out and lube the shifting mechanism under it problem solved
