MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
Advertisement
Thread Tools Search this Thread
Old 11-05-2009, 07:30 AM
Blckmorning's Avatar
Blckmorning Blckmorning is offline
Send a message via AIM to Blckmorning Send a message via Yahoo to Blckmorning
Gallery
Hard to Shift, Clutch not engaging?
i've searched around the Forum and can't seem to find any symptoms that match mine so i'm throwing this out there.
Last year i replaced the Clutch in my 03 MC after it went out at 55k miles. Everything was fine and dandy no problems till just a couple weeks ago i noticed i'm have a really [FONT='Verdana','sans-serif']really REALLY [/FONT]hard time switching gears. At first it was just switching into 1st, and 2nd, now it's all gears. I have to almost Kick the shift for it to go into 1st at a dead stop and almost pull it out of place to get it into 2nd gear. This morning when i got to work, and parked while the car was running i noticed that i wasn't even able to get it back into 1st gear. Almost as though the synchros aren't lined up.
Another symptom i have is that when i do get it in gear and i'm stopped the engine starts to die down almost like i'm pulling up on the clutch a little. however i haven't moved the pedal.
Does this sound like the synchros or possible the slave cylinder? i'm going to change the Fluid tonight, and also try to do a bleed on the slave to make sure there is no air in the lines. But has anyone else had a problem like this?
MITM 2006 | Yalla Yalla 2006 | MITM 2007 | MITM 2009 | MITM 2010 | MITM 2011|
Old 11-05-2009, 01:09 PM
firenewt firenewt is offline
Gallery
Sounds like a problem with the clutch slave cylinder - most likely needs to be replaced. I'm having a similar problem with a new slave cylinder - acts like there is air in the hydraulics.
Kevin
Fizzgig - 2002 MCS PS/PS: M7 16%, Milltek hdr w/cat, Magnaflow catback, Alta CAI ver 2, GRS I/C, Voltage scoop, Thumper head, Newman cam, DT B/V, Brisk plugs, Kingborn wires, exterior blackout, SSR type C 16x7, Yoko AVS ES100 205x50x16, B&M SSK, MM aluminum skid plate, ACT Streetlite Flywheel, ACT HD Performance Street Clutch Kit, Quaife LSD, JCW 380cc injectors, Craven Speed strut tower plates -top/bottom, Koni Yellows, H-Sport springs and RSB, Wilwood BBK front
Old 11-05-2009, 04:28 PM
nabeshin's Avatar
nabeshin nabeshin is offline
Functioning Lunatic
Gallery
Garage
It could also be the shift cables binding up or one snapped.
9/29/2002 EB/W MCS Broken - temporarily retired
Original owner since 2002.
Old 11-05-2009, 05:30 PM
Some Guy's Avatar
Some Guy Some Guy is offline
Gallery
The earlier MINI's had issues with the shift cables getting water into them. If that water froze it could make it nearly impossible to shift.
'05 HB/B MCS.
With: LED lit scoop - DIY AUX cable - Angel Eye running lights - M7 STB - Air horn - Rally Lights -SVT Focus LSD - Poly Control arm bushings - IE fixed plates
UCONN FSAE Engine Systems Head '10-present
UCONN FSAE dyno testing and tuning lead '09-10: www.uconnracing.com
Follow UCONN FSAE on twitter: http://twitter.com/UCONNFSAE
Old 11-05-2009, 05:57 PM
Gallery
Alright... The good the bad the Ugly update....
So i changed the Trani fluid today, while doing so i noticed the shift cables a little corroded because of the battery acid dripping on them... problem 1, second i noticed that the change in fluid didn't really help, so i started working on the slave.
I bled the slave cylinder and noticed the clutch arm on the top of them trani had some play in it.. Is that normal? it also moves up and down about 1/2 an inch or so. is that normal? Either way when working on bleeding the slave... it broke... So either way i have a new one coming in tomorrow about 1030, which is awesome except the fact this means i'm driving my beastly truck. Will update when more info is available.
Old 11-05-2009, 06:49 PM
Gallery
ON a side note, i checked the cables after reading, and even though they are showing signs of wearing, i don't think it's them since when the car is not turned on i can glide through all the gears. I'm hoping that it's just the slave, or kind of hoping it's the clutch. That way i can take it back to the guy that did it and have him re-do it, since it's been less then a year. and half the year the car was driven, because he had it, and because i was unable to drive.
Old 11-07-2009, 06:07 PM
Gallery
Ok i got the car put back together last night, i power bled it 4 times, and still no luck. I still can't get into gear when the car is on. I'm now leaning towards the Synchro rings. I'm gonna take it to my trani guy on monday and have him look at it. Since the clutch was just done a year ago, i still don't think thast it. Unless it's a faulty pressure plate.
Old 11-11-2009, 12:14 PM
moseichuk007's Avatar
moseichuk007 moseichuk007 is offline
Gallery
i have a similar problem on my 03 mcs. recently it back close to impossible to shift into first or second. Even with the car off its not possible to shift into first and second. Ive figured out that if i roll the car just a bit im able to shift into first. This is a real pain though...let me know what your tranny guy tells you, seems like our problems are similar
'03 LY/B MCS
Old 11-11-2009, 01:09 PM
nabeshin's Avatar
Functioning Lunatic
Gallery
Garage
This is sounding more like what happened when my clutch fused to my pressure plate. The car would not shift while turned on, but could be easily shifted when turned off. The clutch pedal felt normal. This was an aftermarket clutch that was not abused, it came out looking pristine. No one could explain why it melted to the plate.
Old 11-11-2009, 01:53 PM
Densmini Densmini is offline
Gallery
It could also be a duff slave cylnder. Have someone depress the clutch pedal while you watch the travel. There should be at least an inch of "throw".
Old 06-21-2010, 06:21 PM
Gallery
OK FINALLY AN UPDATE ON THIS....
So I had my car in the shop about January or so... Just got it back today... due to issues with the manufacture of the clutch and pressure plate, they tried to say that it was driver abuse, which isn't true, and they weren't going to warrant the pressure plate. There were about 3 teeth on the plate that were complete destroyed which was causing the problem. after countless calls, and complaints, and getting about 4 shippments of WRONG parts, they got it right. So round 2 of a new clutch. if this thing fails again i'm going to upgrade it again.
Old 06-21-2010, 11:15 PM
nabeshin's Avatar
Functioning Lunatic
Gallery
Garage
Since January... that is a long time without your MINI.
Old 06-22-2010, 11:56 AM
CrazyIvan's Avatar
CrazyIvan CrazyIvan is offline
Send a message via Yahoo to CrazyIvan
Gallery
What brand of clutch was it?
Ramius 02 MCS, 05 trans with Torsen LSD, Act C/FW ,Alta intake, 15% S/c pulley,2% M7 Crank pulley, Bmp header, Magnaflow CB, Alta IC,PSRS,end links, rear control arms. Eibach front and rear sway bars and Megan Coil overs and Swift Springs.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
