Low Speed Fan Resistor - we need solution
#1351
Low Spen fan not working
Hi Guys. Im almist 100% sure its my resistor that is faulty. I have managed to track a resistor that you guys are talking about. Im just not sure how to connect it up. Do i leave the old resistor in place and then kist cut the thin red wire after the plug on the fan and insert the new resistor between the wire i just cut. If possible can some onr please put pics of exactly how to connect. Mini is South Africa is rediculous with the pricing.
Thanks for the help u guys rock.
#1352
#1353
Any thoughts on this one
#1354
I just finished putting the green Amazon resistor in place. Had to charge some more freon so that the compressor would work that in turn got the low speed fan going. The relay is about 160 degrees F during the fan operation. Going to put some oil into the system as well.
Works like a charm. Kudos to all the past posts.
#1355
#1356
Just wanted to let you guys know. I used the resistor from amazon.com (the green one). I bought this more than a year back and the resistor burned up eventually. I was just going to buy this resistor again and when i checked the review, I saw that one user used this also for a little more than a year and it died on him as well. He talked about going for the arcol version which seems better. And from regular updates we keep getting from Chris Lamb and he used Arcol. So, yea...the amazon resistor is from china and it's probably cheaper quality.
I will be opting for Arcol HS100 R33. You guys could google this and check if this particular model is available from other stores as well (The mouser website, it's out of stock)
P.S. I previously bought from this link
#1357
FWIW, I used two 0.68 ohm green resistors in parallel mounted with thermal grease to the front aluminum bumper reinforcement and they're still going strong after a few years.
I certainly wouldn't be surprised if they are lower quality than the arcol ones, but with the lower wattage being dissipated through each and adequate cooling, they should be fine for a long time. They only seem to get warm to the touch for me which is a good sign.
#1358
#1359
No power to power connection
When I unplug the power connector to my radiator fan, using a test light, I find none of the leads are hot. This is with the ignition on and the AC on. My fuses and relays are fine. When plugged in, NONE of my fans are working. When I checked voltage at my power steering pump fan, I found none! Suggestions?
#1360
I swear to God it's amusing as hell to read all the posts from people who just......can't........seem..........to........... read.
Anyways, just an update for me. On my 06 GP I just replaced the power steering fan, oil pan gasket, and radiator at 80,000.......and to test the power steering fan I turned the A/C on, temp all the way cold, fan on 1.
Lo and behold my low speed fan was not coming on.
I was pretty confident in my connections so luckily I had a spare resistor and swapped it out to test without mounting........and it worked. So now it's all mounted nice and neat.
I ordered my original resistor back in July of 2013....so 4 years it has been working fine........
Another huge shout out to chris.j.lamb who came up with the solution! Thank you my brother!
And for reference this is the exact part that I used:
http://www.newark.com/cgs-te-connect...rfnonsku=false
#1361
OK, Flies, I read the pages of this post for well over an hour and got the gist of the solution for both two wire and three wire cars, BUT I had NO juice at ANY of the three wires on my connector until I cranked it up and got the temp cold. That still leaves the question: can I simply wire the resistor between two of the wires of that connector and if I do, what would be cooling my PS pump when the engine isn't hot or when the air is off? That PS fan needs to on every time the key is on.
#1362
#1363
Leave harness plugged in. Ac on, fan low. Temp all the way down.
Then see if the high speed fan comes on intermittently. You should hear the click of the relay for the low speed fan but be patient. The high speed fan usually comes on after 15-20 seconds or so. Just wait for it and it will only last a few seconds......Then it will shut off.....And after another ten seconds it will come on again.
The power steering fan only needs to be on if the ac is on - ie in the winter the ambient temperature is cool enough that you don't need the extra cooling from the fan.
Of course if you like driving with the windows down in 100 degree weather then it does that work out well......
The power steering fan only comes on if the low speed comes on. You most likely need to do the resistor mod.
#1364
#1365
#1366
#1367
#1368
#1369
So I'm confused.
If you are not getting power steering fan operation, try popping in another fan. I got mine for like $85 oem manufacturer.
Plus if your car is that old it's probably shot like mine was. Could barely turn it with my finger it was so stuck.
Not sure why you can't start your car after disconnecting the battery. It shouldn't be a problem as I've done that a lot and never had that issue. You might have other issues electrically it seems.
#1371
Looks like the part I listed is out of stock on that site. They have an alternative.
Seems like the same specs but I'm not 100% sure. It's also only $7.19 vs $11.02.
Anyone know if this one will work as well?
http://www.newark.com/cgs-te-connect...r47/dp/24M2717
Is it just one has a solder lug and the one you can't solder a wire to the terminal?
#1372
From that I understood you were NOT getting low speed fan operation.
So I'm confused.
So I'm confused.
#1373
None of the wires were hot until I started it with air on and waited 20 seconds as you suggested. Then the red/green wire was hot and the fan came on at low speed, but no voltage showed up at the PS pump fan. The car gas never failed to start prior to disconnecting the battery. But since my keyfob battery is dead, I suspect the immobilizer took action when I disconbected the battery after stopping the engine by removing the engine relay. Starter doesn't make a sound when I turn the key.
But regardless when the fan is on the power steering fan should also go on. Check for continuity.
#1375
So I'm confused.
So I'm confused.
