Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
I'm not sure what to do. I just want to warn all early year Mini owners. I had no warning, noise, signs of this. I just parked one morning and when I got in to dirve home no power steering. Upon further investigation:
Electrical terminal completley burned off!!
Wires into pump fried!!!
I have no idea how my car did not burst into flames!!
Please make sure your power steering pump fans are working. Apparently
mine had locked up and I assume it shorted out the pump. Car is an 11-2002
build S with 58k miles. No warranty and never had any pump work done. It is original to the car.
I'm not sure I have any recourse with MINI-USA but I feel I need make them aware of my experience.
Holy crap. My car is 2 months older than yours and same mileage. I need to check the fan. Whenever I'm under there, I test it and it spins freely. Maybe I should just replace it for piece of mind.
9/29/2002 EB/W MCS 66,670 miles
Original owner since 2002.
+1. Had the fan replaced with the newly designed one about 10Kmiles ago... Recently, PS pump went dead, came back, went dead during the same day. I had it replaced the next day, because even one day was enough to live with the idea of my car bursting into flames. I parked it outside of my house during the night, and at the top level, away from all the cars at work; didn't carry any passengers, etc.
Got the updated version of OEM FAn so no guard is required it is built in....
Tough luck, but good information - that's an answer to a question I didn't know to ask - I have an 02 MCS (07/02 build), bought used Oct. 07 w/ 47k (from a Kia dealer) - just under the car last w/end while replacing the LCA bushings, and that's what my fan looks like (built in 'cage' - guess the previous owner already replaced it
Better be careful...just because your PS fan has the cage/grill covering doesn't mean it is the latest and greatest replacement part. There was an intermediate redesign that had the cage but did not have the extra electronics. I discovered this on my '05 and posted pics here:
Also, if you give any credibility to the NHTSB report on this issue the root cause is purportedly moisture getting into the power cables for the EHPS pump itself and not the fan assembly. BMW has subsequently redesigned both components so it's still anyone's guess...
__________________ PW Peerage #92 - SHADOWFAX - '05 MC PW/B -- Visit my Garage to see Pics and Mods List
"Shadowfax tossed his head and cried aloud, as if a trumpet had summoned him to battle... Fire flew from his feet; night rushed over him." -- J.R.R.Tolkien
Yikes!
So, did the fan die and the pump started burning (but continued to provide power steering for a while) before you parked? (Then was kaput the next morning?)
Holy crap. If your MINI got on fire because of that dumb fan, would insurance cover something like that?
__________________ l 2oo4 P/W MCS l 12-o3 Production l Aero Kit l Alta CAI l 17% SC Reduction Pulley l EBC GreenStuff Brake Pads l M7 Strut Brace Bar l Brisk 14LGS l Kingsborne Wires l Hotchkis 25MM Rear Sway l Clutchmasters Fx2oo + Clutchmasters Flywheel l Stealth SuperSprint Exhaust with MF/ Tips l
Next Mods: l Wheels and Rubbers l Helix SSK l TSW Torque Damper l DT BPV l TSW Springs RMW/Mynes Header l RMW Cam l RMW/Mynes Tune l
Mine went out two weeks ago (same scenario, although I didn't see it to verify that it was charcoal). 02 Cooper CVT. This is my third go-round with the power steering components, including pump replacement, column issues, and now the fan (and wiring harness and thermo). Apparently the fan locked, the fuse blew, the car overheated (quickly), and fused the thermo housing. I'm still trying to fix the resulting problems, and am up to about $1100 at this point (on this month's problem).
I'm really disturbed to see that this seems to be a not-uncommon problem. Personally, I can't believe the wiring harness upgrade wasn't a recall issue, because from what I understand it has either been the cause of my problem, or at least the reason it went from bad to much worse.
I'd appreciate any tips in dealing with my dealer. I tried to go to a private MINI repair person, but his work didn't fix the coolant leak and now he won't return my calls. Indy's definitely no place to own an out-of-warranty MINI.
I also would like tips/suggestions as to this issue. MINI-USA told me to take it to the dealer. If they agree to help out they "MAY" pay for some of it.
I need to get in touch with a service rep.
Judging by some of the comments, it appears that some MINI owners are seeing PS pumps catching on fire for the first time. This has been going on for a looooong time. Just check the sticky at the top of this sub-forum.
Looong time! Not the first time I noticed this, but STILL happening. I just wanted to tell my story. Horrified at the carnage! I was hoping this item was a recall issue. I figured if they recall exhaust tips, why not pump-a-que?
See... you hit the spot. The exhaust tips -apparently- burn people, the failed pumps so far did not burn anyone (luckily). It's crazy how the recall items are determined, dont you think?
Problem is, I see that SCoop hasn't updated the list since April of last year, and has not even posted anywhere on NAM for a year. What a shame -- this first post was a nice running tally but now it's missing valuable, supplemental data.
