MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
new mini owner
19 Replies, 209 Views
Advertisement
Thread Tools Search this Thread
Old 04-12-2009, 11:32 AM
spirit spirit is offline
Gallery
DIY CVT fluid change
I could not find any DIY directions for CVT fluid replacement other than that for the MCS which according to the mini and Bentely manual is lifetime?
http://www.lonestarminiclub.com/foru...read.php?t=474
I noticed that the above instructions did not include running the engine and shifting transmission through all CVT modes, monitoring temperature of the fluid, etc. all while the car is up on a lift. Prior to this they also attached front rotors to axle hubs using four bolts and washers?
Anyway, if it's simply a CVT replacement I could do it but if it requires a lift and fancy shifting through gears, electronics, etc. I'd leave it to either the dealer or a local shop. Does anyone know if the Bentley book instructions are what a mini dealer or good local shop would do?
I'm far from the nearest dealer and would likely rather take it to a local shop to be done if it's not as simple as the link above demonstrates. Is the general consensus to take it to a shop or are there any owners that have repleced the fluid for an R50 on their own?
Thanks in advance.
Old 04-12-2009, 01:08 PM
Motor On's Avatar
Motor On Motor On is offline
Community Servant
Gallery
Garage
If I could find the fluid needed sold in a reasonable quantity for one vehicle I'd be all for figuring it out for folks!
-Drew MMC#282
Follow NAM on Facebook
Old 04-12-2009, 07:06 PM
Gallery
Sounds good. If you happen to figure ii out I'm sure there'd be a bunch of us interested in the DIY instructions.
Any other thoughts out there? I think I'll chat with one of the local mechanics tomorrow.
Old 04-12-2009, 07:16 PM
Dex05S's Avatar
Dex05S Dex05S is offline
Gallery
Thanks in advance.
Did I miss something here or didn't the link say that the instructions were for a manual
Old 04-12-2009, 07:38 PM
Gallery
Yes, bad link. I'm looking for information on how to change a mini cooper non-S CVT transmission fluid. Above I meant that the directions for a mini cooper S / agitronic transmission was recommended as being for the life of the CVT (Bentley Manual). Please disregard above link.
Mini Cooper non-S CVT fluid change information is what I'm looking for.
Old 04-12-2009, 07:56 PM
Dex05S's Avatar
Gallery
I'm with you on this one. My wife has an 05MC and I too need to know the particulars on the fluid change.
Old 04-12-2009, 08:19 PM
Oxybluecoop's Avatar
Oxybluecoop Oxybluecoop is offline
Send a message via MSN to Oxybluecoop
Gallery
Here's how the MINI techs do it.
Old 04-12-2009, 08:28 PM
Gallery
Old 04-12-2009, 09:26 PM
Gallery
That's great, thanks! Seems similar to the Bentley Manual. More than I'd like to handle for my first attempt. However, I think I'll pass along the directions to a local mechanic to see if they're able to do the change for me. If I had access to my own lift I might just have tried to do it myself.
Thanks again!
By the way, what type of online program / manual where you able to get the instructions from? Is this something that only mini dealers have access to?
Old 04-14-2009, 07:09 AM
texic texic is offline
Gallery
I'm not sure what it costs elsewhere but I was able to find the fluid online in a 1 gallon container.
http://www.promini.com/product-exec/...earch_model/99
I accidentally drained my transmission fluid instead of my oil (don't ask). Closest Mini dealer is over 3 hours away so I have to change it myself.
Old 04-14-2009, 08:09 AM
Dustin77327 Dustin77327 is offline
Gallery
Hey I got my fluid for 20 bucks a liter and you run the car on jack stands after you fill it you leave the filler hole open to purge any traped air in the system. The mini dealer by my house only charges 180 for the service
Old 09-26-2010, 08:33 AM
Soupamoto Soupamoto is offline
Gallery
I see some of the pic links are gone for this thread. Anybody have any update on changing the CVT tranny fluid yourself and/or can you repost the missing pics? thanks
Old 09-26-2010, 08:36 AM
Gallery
Hey, also, are there now suitable substitutes for the CVT fluid that come from other sources than BWM/Mini? Here's a couple links to what appears to be alternatives:
http://www.amalie.com/specs/4b_trans_cvt.pdf
http://www.partsgeek.com/catalog/200...s-t_fluid.html
Can anybody confirm these fluids are OK for the Mini CVT (my car is a 2004 non-S)?
Old 12-29-2010, 09:22 PM
mellow1771 mellow1771 is offline
Gallery
Mister Oxybluecoop
Old 12-29-2010, 09:28 PM
Gallery
Could you please show R50 CVT DIY again?
The pictures does not show now.
Thanks.
Old 12-31-2010, 10:10 PM
Tahoe_Ron's Avatar
Tahoe_Ron Tahoe_Ron is offline
Gallery
There are two ways to fill the CVT. (1) From the fill hole on the pan, or (2) from the fill hole on the top of the CVT. I choose (2) because it is awkward to add the fluid from the bottom unless you fix up some kind of hose to pour it in.
To use the top fill, you must take out the battery box to get to the hex plug. This plug is a tight fit, requiring me to use a breaker bar. Removing the battery box involves disconnecting a couple of electrical connectors, but it's not too hard.
Measure how much you drain. It should be 4.5 quarts. The easy way is to just add 4.5 quarts of new stuff. The business about shifting the gears, etc., is overkill if you are just doing a drain and refill. If you fill from the top, you can still use the bottom fill hole to check the fluid level.
I also did the filter which requires taking off the pan. It was very hard to take out some of the 10mm bolts, so this could be frustrating. It is doubtful that you will ever need to change the filter.
'04 MC Red/White CVT
Old 02-02-2011, 08:41 AM
gknorr gknorr is offline
Gallery
Quote:
Was your used filter pretty clean?
Usually changing filters for things at some point would be regular maintenance. I'm at 114k miles and thinking a new filter with my next fluid change might not be a bad idea.
2003 MC CVT BRG - 121000 miles
Old 02-02-2011, 04:01 PM
Tahoe_Ron's Avatar
Gallery
The filter is encased in a metal housing, so I couldn't see much. Mine had only 40K miles, so you have more reason than I to change the filter. Nevertheless, I have not seen any recommendation that you need to change this filter, and it's a bear to do.
Old 02-02-2011, 05:31 PM
vIPkOhH's Avatar
vIPkOhH vIPkOhH is offline
M1N1-AZN
Gallery
Garage
There is a How-to here http://www.mini2.com/forum/first-gen...t-2.html...btw have anyone experienced this altenative http://new.minimania.com/web/Item/NMG7298/InvDetail.cfm
Old 02-02-2011, 06:44 PM
Gallery
I also haven't seen any recommendation to change it. Even the official document from ZF only mentions fluid changes every 45,000km. It still seems like something that should be done at some point, but when that is is anyone's guess.
What else would be involved for the filter change besides the 10mm bolts tightened almost beyond the ability to be loosened?
Old 02-02-2011, 11:07 PM
Tahoe_Ron's Avatar
Gallery
It's not that the bolts are too tight, it's that a couple of the bolts are almost impossible to get at with a socket or wrench. The official way to take off the CVT pan involves removing sub frame parts.
Old 02-03-2011, 05:41 AM
Gallery
I see - I'll have to take a look at this next time I'm under the car. With the difficulty of getting at them, did you concede and end up removing any of the sub frame parts?
There are a few jobs when the official way calls for removing subframe parts when it certainly does not need to be done - I think the inner tie rods are one example.
Old 02-03-2011, 04:04 PM
Tahoe_Ron's Avatar
Gallery
I was able to get all the bolts off. I took a 10mm 1/4" socket, ground a side flat so that I could get the socket on the bolt and turned it with an open end wrench. It can be done.
Old 02-18-2011, 09:57 AM
justincummings justincummings is offline
Send a message via Yahoo to justincummings
Gallery
Bentley Manual...
Is there a how to for this in the Bentley Manual? My nearest dealership is 2 hours away and wants $500 for all the parts, fluid, and labor. That seems outrageous. I'd love to take on this project myself some part #'s and pics that give us a step-by-step would be VERY helpful.
Old 02-19-2011, 10:50 AM
Gallery
I'm not sure what's included in the Bentley manual for this - haven't picked up a copy yet (probably should have long ago!).
However, you might find this link useful as a how-to for the fluid change. It's not perfect, but it's at least a good start:
http://www.mini2.com/forum/first-gen...acement-2.html
Only thing I wouldn't recommend following is his fluid recommendation. I would use either the recommended Esso fluid or a non-slip CVT fluid. Redline makes one which I plan on using.
Also, there seems to be a consensus that you should overfill the fluid, run the car a little, go through all the gear ratios (manual mode), and then open the "fill" plug further up from the drain plug to let the extra fluid drain out. Once the extra fluid drains, you should be good to go.
This picture I grabbed from another forum post somewhere might help.
I would do your filling from the plug on top of the transmission, not the "fill" plug in the above picture. It should be much easier to get to and fill from than the "fill" plug. To get to it, you just have to remove the battery box.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
