If my memory is right, my Clubman S turbo cooling fan ran after shut off even in colder weather at the beginning of the winter. I'm in Louisiana and the weather isn't really cold anyway.
A couple of weeks ago, I noticed that the fan wasn't running after shut off, instead I would occasionally hear a sound like something was trying to stop and start. Now I'm getting nothing.
Before the dealership tells me that "it's supposed to be that way", I thought I'd see if I should expect the fan to run on after driving say an hour or two in 70 degree weather?
__________________ "BERNARD" Laser Blue/Silver '08 Clubman S etc, etc
Ordered 7/25/08, Born 8/2/08, Home 8/30/08; Week 32 Support Group!
The fan is on a temperature switch and will only run after shutoff if needed. Mine usually does not run after my 12 mile trip to work on the highway during weather colder than 22-23 degrees. BU t if it is warmer than that i does usually run.
If the car is only run for a couple of miles and did not warm up then the fan probably will not run.
08MCCS, HC/HC/Blk, 6 SPD, Premium, Sport, Cold Weather, Convenience, HiFi, HC L/C - Steering Wheel - Shift Knob-Boot, - E Brake Handle-Boot, English Oak - 17" Web Spoke (R98) Painted H/C, H/C Club Member #42.
It all depends on how hot your engine gets no matter what the temp outside is. Too many factors involved to say yes or no you have a problem. It's usually 80 degrees here in Hawaii and when I get home from work, sometimes the fan runs when I stop the car and sometimes it doesn't. It depends on how long I idled at a traffic light right before turning into my house. I think unless your car is overheating you have nothing to worry about.
__________________ Mini Me - 2008 Laser Blue/Black MCS - 6 sp Auto, Multi-Function Steering Wheel, Piano Blk/Anthracite, Black JCW R105 Double-Spoke 18-inch Wheels on Pirelli PZero RF
It also has makes a difference if you run the compressor or not. The fan comes on automatically if your A/C compressor is running. This puts an extra load on the engine and it will get warmer - faster.
Check to see if your fan fuse is blown, it's either a 30A or 40A fuse in the engine bay on the driver's side. If it's blown, it's probably a 30A and needs to be replaced per campaign, with a 40A fuse.
R55 Front brakes FS, calipers/rotors/pads
Wood Steptronic shiftknob FS PM for further details.
