MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post R53 issues
11 Replies, 467 Views
Go to first new post SHOW us your MINI stripes
586 Replies, 114,798 Views
Advertisement
Thread Tools Search this Thread
Old 12-31-2008, 04:38 PM
yellowbritishrocket's Avatar
yellowbritishrocket yellowbritishrocket is offline
Send a message via AIM to yellowbritishrocket Send a message via MSN to yellowbritishrocket Send a message via Yahoo to yellowbritishrocket
Gallery
coolant leak
yesterday i went out to my mini before i left to check the fluids....the fluid in the exp tank was a bit low so no biggie i replaced it and went on about my day...while my car was at minicorsa getting work done i noticed dried coolant on the frame and a very slow drip coming down....this morning i went out to my car and checked and the coolant was sitting on the Min line...and there is a small damp spot on the ground....here is the interesting part...its not coming from the t-stat or rad hoses i just replaced those with samco ones...it seems to be coming from the nest of hoses in the back of the engine bay cuz i ran my hands around back there and came up with coolant on my fingers...has anyone had the same problem and where i can i find replacement instructions for those hoses and part numbers
tks all
Old 12-31-2008, 05:38 PM
Some Guy's Avatar
Some Guy Some Guy is offline
Gallery
It's not the thermostat it's actually the thermostat housing, it is some crappy plastic thing that likes to break. I had the coolant showing up in the same place you mentioned and it was the thermostat housing.
What year is your MINI?
'05 HB/B MCS.
With: LED lit scoop - DIY AUX cable - Angel Eye running lights - M7 STB - Air horn - Rally Lights -SVT Focus LSD - Poly Control arm bushings - IE fixed plates
UCONN FSAE Engine Systems Head '10-present
UCONN FSAE dyno testing and tuning lead '09-10: www.uconnracing.com
Follow UCONN FSAE on twitter: http://twitter.com/UCONNFSAE
Old 12-31-2008, 05:47 PM
minimarks minimarks is offline
Gallery
Yep, my money is on the housing... Replaced mine a couple months ago under warranty.
'06 SB/SB MCS, H-sport Comp RSB, JCW SB, TSW Springs, Bilstein, TSW control arms, Powergrid, Vorshlag Camber Plates, Powerflex, Goodridge, JCW Brake Kit, ADO8/RPF1, 15% Craven Pulley, JCW CAI, K&N, PNI, VIP engine damper, Milltek, Nuvi, Helix Short Shifter, MOMO, GP IC, RMW 450 injtrs, RMW Cam, RMW Header, Jan Tune...
Old 12-31-2008, 05:50 PM
Gallery
nope its neither....i looked at the hoses in the back and there is one with coolant around it...has anyone replaced those hoses in the back and if so how was it done....are those hoses pressurized like the rad hoses?>
Old 01-01-2009, 06:58 PM
Gallery
anyone replaced the hoses in the back...any special procedure?
Old 01-01-2009, 10:49 PM
k-huevo k-huevo is offline
Gallery
There are input and output hoses going to the heater core, I replaced one of them because it had worn through from rubbing against a power steering reservoir hose. The OEM replacement I ordered took too much time (3 months from Germany) to arrive so I found a similar shaped generic piece and cut it to fit. When you remove the expansion tank cap it releases pressure, so no problem with that, but be prepared for a coolant spill when you pull the damaged hose.
Old 01-01-2009, 11:36 PM
Gallery
ive replaced the rad hoses so itll be nice not having to deal with tearing the front bay all the way apart
Old 01-03-2009, 10:45 AM
manicrodder manicrodder is offline
Gallery
I noticed a leak under my MINI last week and parked it until my appointment yesterday. It was the stat housing. I picked it up just before they closed and now the clutch is grabbing. I don't know how this relates but I have called them. Service is closed till monday.
Old 01-15-2009, 01:58 PM
FastGreenMINI FastGreenMINI is offline
Gallery
thermostat housing
had the thermostat replaced then re-replaced a few months later under a warranty from the shop. It was overheating and that seemed to fix it. Now they say its leaking from the housing and will have to be replaced. Will I have to replace the t-stat again while doin so? Im just going to do it myself, doesnt seem to hard. I have the same grabby feeling in the clutch and its gotten progressively worse over several months. Its gotten very hard to shift correctly and everyone says to replace the clutch master and slave cylinders.
Old 01-15-2009, 02:19 PM
Gallery
My clutch seems to be back to normal now. Hopefully it stays good. It was driven less than 100 miles with the leak.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
