Help! New tire vibration!
Hello, I just replaced my OEM runflats with these:
http://www.tirerack.com/tires/tires....nSpeedRating=H
(if the link doesn't work, they are: Bridgestone Potenza G 019 Grid, non-runflat, 205/45R17, 84V)
I had them done at Brecht Mini. I am now having a problem. Either all four (there is some slight steering vibration) or the back two tires (yet most of vibration feels like it's coming from the back) are vibrating at highway speeds. I've driven about 100 miles on the tires now, and they vibrate on all surfaces... the higher the speed the more pronounced the vibration becomes. The vibration starts around 50-60 mph.
What could be causing this?? Did the dealer screw up the install? Are the tires defective? The dealer left the stickers on the tires when they installed them, could that have anything to do with it? It's bad enough that my fiancee can't ride in the car without getting car sick.
Also, I'm afraid if I take the car back to the dealer they would just blame the tires (because I didn't buy them from them) and not make a serious effort to diagnose or fix the problem.
This problem has me really frustrated if anyone could help that I would really appreciate it!!!
New Tires Vibration
Hi I also replaced my Goodyear run flat tires with new wheels and snows Bridgestone WS-60 and 15" wheels. I to have a vibration - seems to come from rear, but not totally sure. Had the tires re-balanced still had the vibration, checked tire pressure and adjusted. Again starts at 50MPH I did read that the tire and wheel run out may be an issue but not sure if Town Fair will know or have equipment to check run out. This is frustrating as the summer 16" tires are great. but cannot use them for about 4 more months. After checking I did find this info:
http://www.yokohamatire.com/pdf/tsb-...ance-12803.pdf
This is unlikely to apply to the OP, but when I lived in Colorado, most of the roads were county-maintained gravel roads. They got pretty muddy after a rain and several times I had vibrations in the steering (didn't have a MINI then, by the way) when I got on paved roads.
Turned out that mud (or sometimes packed snow) had gotten on the inner side of one or more wheels in an uneven pattern and thrown the wheel out of balance. My first step was to spray wash the inside of the wheels...this (almost) always seemed to cure the problem.
I just went with ROTA wheels and 16" whhels on my MINI, and have a similar slight wheel vibration. My wheels are currently "Static" spin balanced with weights in one position only on the inside center on the wheels. I am going to have the wheels "Dynamically" balanced with weights in the inside center of the wheel and on the inside lip of the wheels. This balancing process is supposed to eliminate both up and down as well as side to side vibration. My vibration on the wheels is minimal and some times almost impercebtable, but it is there. As one other poster said, for the very best balance, get a RoadForce balance on the wheels/tires. It's expensive, but when done right makes the ride smooth as glass. I am going to try the Dynamic 2 position spin balancing first on my wheels....good luck!
Why be afraid of Brecht? If they installed them, they need to stand behind the workmanship of the installation, which includes proper balancing. Besides, they had their chance to disagree with your choice of tires when you first brought them into the shop for installation. Since they didn't say anything during the installation, they can't say anything about the tires now.
