MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Swift vs H Sport
by putttn
0 Replies, 13 Views
Advertisement
Thread Tools Search this Thread
  #51
Old 08-09-2008, 12:18 PM
Nitrominis's Avatar
Nitrominis Nitrominis is offline
Gallery
Quote:
Originally Posted by Ancient Mariner View Post
Whew! This thread managed to pull up just before it hit the ground!
Maybe.
Silly question, Hag, but are you clearing the codes between fiddling with the problem? If it's staying in "limp home" mode, it will just be adding to the confusion.
and Nitro, a pint of fish oil in the tank keeps the injectors running really great. The down side is that any one following you thinks you are doing delivery for a fish 'n chips shop. And the cats. Oh, lordy, the cats!
Not to worry I have all the solutions !!!
The smell of victory has never been better!
Why deal with the nauseous exhaust fumes from your race vehicle, when you could be sniffing root beer, pina colada, or bubble gum instead? Manhattan Oil fuel fragrances eliminate unpleasant exhaust fumes and the eye, nose, and throat irritation that come with them. Just mix them in with your regular fuel--one 4 oz. bottle treats 30 gallons of alcohol or 20 gallons of gas. Plus, they're available in 19 different fragrances
http://store.summitracing.com/partde...5&autoview=sku
  #52
Old 08-09-2008, 03:29 PM
Haggardsk8er Haggardsk8er is offline
Send a message via AIM to Haggardsk8er Send a message via MSN to Haggardsk8er
Gallery
It's not in "limb mode"... its just got wierd vacuum issues I believe, but this could be due to the 02 sensor... so this has yet to be addressed... been busy this week so no time to find a sensor....
I'll check that link above...
Thanks again guys for your support here.... I'm sure we'll get it figured out, and than I'll treat you both to Fish & Chips....
www.TeamHalfa$$.net
Way to go Moderators!!!!
Long live El JEFE UKSUV
  #53
Old 08-09-2008, 03:30 PM
Gallery
I'm sure the Inj will love some strange additive in the system......
Do they have scent??
www.TeamHalfa$$.net
  #54
Old 08-09-2008, 09:57 PM
Nitrominis's Avatar
Gallery
nope
http://www.manhattanoil.com/fuel-fragrances.php
  #55
Old 08-27-2008, 10:40 AM
kenatminimania kenatminimania is offline
Gallery
You can always try swapping the pre and post O2 sensor to see if the condition changes. The two sensors are identical.
ken
  #56
Old 08-27-2008, 12:23 PM
jm6001 jm6001 is offline
Gallery
All I know is that i had both the MAP and the too much boost code before.. I took it to Mini because my car was still under warranty and first they blamed it on my detriot tuned BPV so i took it off brought it back to them and there was still the two codes erroring.. so end of the story is they replaced the MAP sensor and everything worked fine after that
  #57
Old 05-19-2009, 09:30 AM
Vincent Hill Vincent Hill is offline
Gallery
Alright so after driving around for over 6 months with the SC breather line that runs up the the vent valve on the upper lefthand side of the valve cover, because these were on backorder, they finally came in today and I installed it, only to have the problemo not fixed
If I leave it unplugged from the valve, the car runs and idle's prefect... as soon as I plug that shizzle in, the car runs smoother and when I'm driving, once you let off the gas and let the RPM's come back down to idle... the car dies, 80% of the time...
My question is this... why, when the line that comes plugged in from the factory, if left plugged in makes the car stall.... Something is a miss here and I am at a loss as to what it is... Any help in this area would be SWEEETTT.....
The P030 Code, did you ever get this resolved?
I have an After market Header system that puts the O2 sensors very far down stream. I just had a New Cat welded in where only a Silencer was. I had 2 old O2 Sensors over 100,000 miles so I carefully cut in 2 new ones using Silver Solder and staggared so the Protective cover would fit! Now I have reprogrammed the car and got rid of the Cat related codes, but came up with this new code! Today I checked the resistance on the New Sensor vs the Older one and they were very close 3.5 for the New and 3.4 for the older ones.
I need to try to switch the Sensors to see if I just got a Faulty O2 sensor or what! This can get very tiring!
  #58
Old 12-21-2010, 11:05 AM
gknorr gknorr is offline
Gallery
Quote:
ken
I second this. I was getting pre-cat O2 sensor codes even after replacing the pre-cat O2 sensor. I switched the pre and post sensors just to see if anything would change, the post sensor being the original MINI O2 sensor. And...code disappeared. Turns out the new O2 sensor I had installed was not within proper spec. for the more important pre-cat sensor which determines the fuel/air ratio.
If you get a new O2 sensor I recommend getting an NTK (original manufacturer), or a MINI O2 sensor. I still got the code with a Bosch and ACDelco in the pre-cat position.
2003 MC BRG soon-to-be 6-speed formerly CVT - 121000 miles
  #59
Old 06-23-2011, 07:02 PM
mjlwriter mjlwriter is offline
Gallery
Need information about Crankcase vent valve install
Gary:
Have a dip in RPMs upon starting up. Had a throttle body cleaning service today and it did not help things. The thing that I would like to try next is a crankcase vent valve replacement. I can easily get my hands on one, and looking at where it is on the diagram and under the hood, it looks easy. But what exactly is required to do the swap? All I see is one nut, no clamps, etc., as see in diagram. I have a 2002 base MINI Cooper. Thanks.
  #60
Old 06-24-2011, 08:53 AM
Gallery
Quote:
Originally Posted by mjlwriter View Post
Gary:
VERY Easy! The Rubber hose pulls off and yse there is only 1 10 MM Head screw holding it all in place!
  #61
Old 06-24-2011, 11:52 AM
Gallery
What is the easiest way to get that hose off the existing valve? Someone told me to spray it down with something, for example WD40, let sit overnight. Then remove it. Is this necessary? The hose does seem rather "stuck" (I haven't pulled on it yet, though). Any advice to help this go down without incident? And would WD40 damage the rubber hose?
Do I loosen the screw and remove the valve first or remove the hose first?
These elemental questions will help me do this job and not damage the hose, etc.
thanks
Quote:
  #62
Old 06-24-2011, 11:58 AM
Gallery
Remove the valve first then it is in your hand to hold the Hose and twise the valve out. If it tries to become difficult, take a very small screwdriver (Like you see in the plastic cases where the smallest one is used to tighten up the screw in Eye Glasses) and pry with a little twisting and lifting motion all of the way around and then if necessary spray some WD 40 and run the screwdriver around the edge again. Once you are holding the valve and are able to twist it on the hose the job is done. These hoses once were all replaced because they use a grade of rubber that split! Just another little something where Mini did not do any Homework at all!
  #63
Old 06-24-2011, 12:25 PM
Gallery
Vincent, that is good perspective, but two things:
1) When you say, "... and then if necessary spray some WD 40 and run the screwdriver around the edge again," I assume by "again" you are saying that I am using that screwdriver initially too, as in where you say, "pry with a little twisting and lifting motion all of the way around."
2) Could this repair (don't even know if the valve is shot...) correct the following symptom: When start the car, tachometer goes up to the normal ~900RPM, then drastically dips to ~600RPM, then ramps up to ~900RPM again. At the point where it dips to ~600RPM, the car shakes as if it's going to stall, but it doesn't as it ramps back up to ~900RPM.
I unfortunately went to a mechanic yesterday for "throttle body service," thinking he would do it the right way. Seems all he did was access the air filter box and shoot cleaner in there while someone hit the gas. This isn't the correct process, as things would've needed to be disassembled and the throttle body cleaned in more of a hands on fashion. He also broke clasps and a zip tie along the way. Not good service.
Please provide your perspective. And thanks!
  #64
Old 06-24-2011, 12:42 PM
Gallery
I do not think this would cure that! WHen my Porsche does the same thing is is ALWAYS because the Air Fuel Mixture is RICH. If your Idiot light is on I would suggest going to AutoZOne and having your codes read. If you took your car somewhere to have the throttle Body cleaned and your are afraid of hurting the hose to the PCCV valve I would avoid getting in too deep.
The reasons the car can run rich are usually clogged O2 sensors that are not reading correctly and that 99.9% of the time will cause a Code to be thrown. The PVCC Is fairly cheap and easy to replace and you have nothing to lose
  #65
Old 06-24-2011, 01:34 PM
Gallery
Thanks.
I had the O2 sensors changed recently and this condition persists after the change. Never have actually had engine lights or codes, just the symptom I noted. The place that did the throttle body service never had instructions to be careful with any hoses. They just got jammed up and did the minimal work; never did disassemble, just hit the air filter box while someone revved... Their $29.99 service didn't help.
So, have new plugs, plug wires, OEM O2 sensors, ignition coil, fuel filter, air filter, new battery, recent synthetic oil change, etc., and still have this symptom. Not sure whether it is emission or ignition related, but it is frustrating.
Will do the seemingly easy and otherwise likely necessary PCV valve replacement and will hopefully derive results.
  #66
Old 06-24-2011, 01:47 PM
Gallery
Fuel Filter? Is this a Mini Cooper or Mini "S"? I know for sure that the "S" does not have a Fuel Filter. It has screens on the fuel pump in the tank.
There are not that many lines (Vacuum or otherwise) on a Mini. Your problem is perplexing allright and I thought I had seen or had most of them. The Mini usies a Chrysler Neon "BASED" engine built in Brazil. One of the things they did to make more power was to shorten the Valve Guides. This causes the valves to start to wobble around 90 to 100K Miles. I had to replace the cylinder Head on ours when I checked the compression it was low on 2 cylinders.
I do have 1 last question. Do you know the condition of your Catalytic converter? Exactly how many miles do you have and exactly what car do you have. Also to see if you have any vacuum leaks try spraying Carb cleaner around the engine such as the lines and throttle Body. If anything is leaking, the rpms will rise and then fall as the vapors burn out. You may have to break down and take it to the Best Dealer you can find and hold your hands up while they Robb you to see what they say at this point!
  #67
Old 06-25-2011, 05:53 PM
Gallery
This is a 2002 MINI Cooper base model (no "S"). Definitely a fuel filter in this guy and I swapped it out. Probably a good idea for there to be none in the S, as this was a hellish task.
I have ~105k mi. on this vehicle. The weird RPM dynamic I've described occurs only during start up, not during idling or regular cruising.
Only thing I will do now is replace the PCV valve on the chance that it is bad. Hypothesis: I was thinking that due to pressure build up at start up due to faulty PCV valve, some sensor causes the RPMs to go down initially, then PCV valve does open and relieves the pressure, and sensor then allows RPMs to go up to normal idling level.
Who knows? Can't worry about it too much, as the potential diagnostic cost is prohibitive at this point, since the problem doesn't affect actual drivability.
I appreciate your help thus far, including the best method to deal with the PCV valve replacement. Will do on Monday.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
