R53 Power Window Problem
Old 08-01-2008, 06:15 PM
licoptman's Avatar
licoptman
licoptman is offline
The drivers side window of my 04 s doesn't work at all. I can hear a click when I hit the switch but nothing happens. Does it have a relay somewhere?? Afraid I might break the window if I don't fix it soon, please help!
Old 08-01-2008, 06:19 PM
Krut's Avatar
Krut
Krut is offline
Common problem - motor relay is dying - while holding the switch to make the window move, thump the door panel - above the speaker, below the door open handle. That might unstick the relay in the motor.
Old 08-01-2008, 07:17 PM
guidmini's Avatar
guidmini
guidmini is offline
Lico. Try tapping on the glass. Not to hard or you could break it.
when its all the way up. door opnen tap on top of glass which holding the switch in down postion may come back alive.
If not bang on the door panel right below the tweeter above the midrange.
goodluck
Old 08-10-2008, 05:24 PM
rodH's Avatar
rodH
rodH is offline
This banging on the panel worked for me, but what is the perminent fix?
Old 08-16-2008, 06:54 PM
tropicatango's Avatar
tropicatango
tropicatango is offline
it is the window motor in the door, got same problem
Old 08-28-2008, 11:04 AM
pepegrande008's Avatar
pepegrande008
pepegrande008 is offline
anyone know where the fys thread for the window fix??? or if there is one. driver side went last year and i spent like $300 on fix. I know i can do it myself now that the passenger side is shot
Old 10-29-2008, 11:01 PM
imortalsin84's Avatar
imortalsin84
imortalsin84 is offline
i have the same problem...but on my car it sounds like when the automatic door locks go on it is doing some type of cross short cause it messes with my passenger door speaker...and when i first heard it do that i realized my window didnt work after that
Old 12-07-2008, 03:41 PM
Goodwood's Avatar
Goodwood
Goodwood is offline
Thanks!
Passenger window on my daughter's '03 CVT quit, but I could hear the clicking when activating the switch. I bumped the door panel with the side of my fist as prescribed above and "voila!" the window's working again, just fine thank you.
I understand this is still probably a problem that will re-appear when whatever is wearing out wears out further... anybody have a guess as to how long I can get by on just thumping the door panel?
Thanks again NAM, you saved me a few hundred bucks probably, at least for a while.
Old 12-07-2008, 05:42 PM
splicer65's Avatar
splicer65
splicer65 is offline
I have been doing the "thump" about once a month for almost 2 years! But, my 72K '03 S will be gone this week. I give up Hello Honda Accord .
Paul
Old 12-07-2008, 06:14 PM
Xer0 Ph0kus's Avatar
Xer0 Ph0kus
Xer0 Ph0kus is offline
Well this is eerie, I literally just 10 minutes ago had this problem on the passenger side window. I came here to see if anyone had a fix and what do you know, I see your topic 3 down from the stickies.
Awesome for the help, my car is still under warranty so when I get back to being around a dealer I might just take it to them and have them fix it up for me, until then though, I'll be thumping away.
Old 12-07-2008, 09:20 PM
MrCooperS's Avatar
MrCooperS
MrCooperS is offline
Moderator
Actually this is a very common problem. My passenger side window motor died. When my mechanic took it apart to look at it, he brushed off some shrapnel and debris, and now it works. However, I feel like my window motors on both window is moving slower and slower going up and down.
iggi
17
09-02-2023 03:06 PM
07-16-2020 12:54 PM
12-23-2015 10:36 AM
wkp1219
11-13-2015 07:52 AM
08-12-2015 01:24 PM
Quick Reply: R53 Power Window Problem
