YES, I have searched and read the many posts. BUT on my 04 MC the process does not work Any ideas ? Here is what I am doing
Press and hold the trip odometer button.
Insert car key and turn it to the first position.
Watch for the word "RESET" to appear on the Odometer indicator.
Release the trip odometer button, then press & hold it again.
Wait for the "RESET" message to flash.
Release the button, and then press & release (once only)
The Service interval is now reset to 10,000 miles
I never get a RESET message
None at present
wife's MINI's CVT went bad and we wholesaled it ;^(
My DD is a 99 Vette ;^)
Try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
I had to do this several times (3) before it worked on my 04 MCS and it reset to 15500 but that is OK with me.
__________________ Deuce is a 2012 S Coupe CR/SLV JCW package, Cold weather ,and Premium packages. Rooser red color line, White turn signals, Piano black dash, Xenons, Black headlights, Black driving lights, Rear fog light
#43 Street Modified (SM) Class SCCA Hawaii Region
2005-2009 Solo Run Off and Points Champion (Hawaii)(2nd 2006 Points)
2005-2008 Overall PAX: 8th 2006, 7th 2007, Tied 10th 2008.
2010-2011 Modified FWD RallyCross (Points Champion) http://www.sccahawaii.org/pics2008/s.../img_38944.jpg
__________________ PS/B '03 MCSl RMW Tune l JCW 380's l ALTA 15% Redux Pulley l ALTA 2% Crank Pulley l ALTA CAI w/ hose l ALTA Intercooler Diverter l B&B Exhaust l Kingsborne Wires l IK22's l Team-Dynamics PR1's l JCW BBK l M7 STB l Vogtland Coilovers l Madness 19mm Rear Sway Bar l Helix SS l MinSpeed TS l STRI Gauges l PIAA 540's l Clear Tails l Rear Fog l Aero Grills l
Yes, thanks.
I edited my error so it can work now.
Sorry, don't know of a way to set for 10,000 miles. Just reset @ 5,000.
The procedure worked extremely well on my 04. It reset at 15500. I am very happy that I did not need to buy the Peake oil reset/fault code reader tool.
I do my own oil change now and the factory 3yr/36k maint. is already expired. Do I need to wait until it gets to zero before doing the reset? I have had the car for almost 4 years, the counter never reaches zero after 4 oil changes, 2 factory (low-mileage annual oil change) and 2 self done.
Need a little advise here. I attempted to reset the oil change counter because it's down to 75 and my factory covered maint was expired. I have been changing oil myself since. I tried following the instruction found in the Alliance news letter and it did not look like anything I read. Here is what I saw on the car:
1. Pressed and held trip button
2. Switched key to 1st position
3. Saw "reset" then "51A" showed
4. Released and held down trip button again
5. Nothing happened no matter how long it was pressed
6. Tried couple more times, and one time I saw "END" appeared
7. Somehow, the "inspection" counter shown with "15500" miles
Now, instead of showing oil interval everytime I start the car; it only shows "Inspection mile" counting down from 15500. Is it normal, did I do something wrong. My ride is a 2006 model and the counter was never reset by the dealer due to very low miles driven.
