MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
Advertisement
Thread Tools Search this Thread
  #26
Old 12-13-2007, 09:24 PM
minicobra1's Avatar
minicobra1 minicobra1 is offline
Gallery
Ok, so I wasn't hearing things then. I listened to the video on the Mini2 site and that is exactly what my car sounded like the other night.
It was parked all day at work and was cold out, (for California) about 42 degrees.
When I started it up, it sounded like a diesle truck motor, something was rattling or metal on metal type sound. I ran it for a few seconds and then turned it off. When I turned it back on the sound was there, but then quickly went away.
I pulled into a gas station and raised the bonnet, thinking I might be able to see something, but of course I couldnt. The drive home was fine and I haven't heard it since, so I guess I'll just wait and see if it comes back or if someone finds the source to this, I'll bring it in to the dealer.
Braden - 07 MCS, DSM, Comfort Acc.,Blk Roof/mirrors, LSD, SPT Pack, Navigation, JCW Stage 1 Kit, Clear Lens, Piano Black, 17" Konig Feathers, Eibach Pro Springs, Eibach Rear Lower Control Arms, Ireland Fixed Camber Plates, Alta 19mm Bar. www.myspace.com/petroleum
  #27
Old 12-14-2007, 03:52 PM
Bishamon Bishamon is offline
Gallery
After about two weeks without incident, mine made the noise again today. This time the temperature had dropped to around -2 Celsius while I was at work, and the car sat for around 8.5 to 9 hours in the parking lot. This was the worst it has been yet, but it still didn't sound bad while idling, but as soon as I gave it any gas at all, around 1200rpm, it would start to get loud, and only became louder as it approached 2000rpm; I didn't rev any higher. I let it idle for around three minutes, and it was still there if I increased the revs... at four minutes, it was still there. Finally, after about five minutes I turned it off and back on... oddly enough, when the engine started and the tach hit 2500rpm+ (whatever it hits briefly when starting), it sounded normal, but again if I gave it much gas it would get loud, but not as loud, and now only at closer to 1800 or 2000rpm. It had become much more quiet, so I pulled out and started to dive. By now, about seven minutes (or more) had passed, and it was sounding pretty normal. I drove home without any probems.
I don't know what to think at this point.
http://www.northamericanmotoring.com/forums/signaturepics/sigpic41885_2.gif
  #28
Old 12-14-2007, 04:38 PM
dneal's Avatar
dneal dneal is offline
Gallery
Bishamon - If the sound was a knock, it's a classic symptom of piston slap. Read the Canadian Driver link to understand it, go easy on the motor until it warms up, and don't worry about it.
  #29
Old 12-15-2007, 06:06 AM
Gallery
Quote:
It sounded much like the links posted in the thread on Mini2. I hope that it's only piston slap, but I doubt it.
  #30
Old 12-16-2007, 06:00 AM
korby korby is offline
Gallery
There starting to replace engines ! http://www.mini2.com/forum/2nd-gen-f...n-cold-14.html
  #31
Old 12-16-2007, 07:43 AM
Gallery
Quote:
I'm watching the thread closely. Others have stated that they have had the problem fixed before by replacing parts or repairing things that the dealer said would definitely fix the problem, then jumped in the thread proclaiming the issue was fixed and their car was silent, only to report back later that the sound had returned. Now, it is likely that replacing the entire engine would resolve whatever is causing the problem, but until I know for sure I won't be asking my dealer for a new engine.
  #32
Old 12-16-2007, 05:36 PM
minicobra1's Avatar
Gallery
Well, if it is an oil problem, such as not enough pressure, pump too slow, oil frothing, this will cause a lot of pre-mature wear on the engine, especially being an aluminum block.
We should all report this to the dealer ASAP, the problem may be sporadic, but some people were running there engines for a pretty long duration before the noise went away.
I've been paying close attention to mine, it hasn't done what it did that one time, (lasting for about a minute), but if a listen real close I can hear that sound for about 1 sec almost every time I start.
The real problem is that this pre-mature wear may not effect replacing parts until the warranty is up. Most engines should last 100K plus, but this may cause our engine to wear out in the 50-60K range, long after the warranty has expired. Of course, maybe by that time there wil be enough people experiencing the problem for them to issue a mandatory service recall and possible extend the warranty if it becomes a very common issue.
  #33
Old 12-16-2007, 08:23 PM
ianparcher ianparcher is offline
Gallery
I went to Mini about the knocking I was getting on cold starting (below 32degs). They keep the car for the day. When I picked it up they said they heard the noise and its normal. They gave me some BS about its a double injection pulse when the engine is cold. I said I know the difference between direct injection pulses and engine knocking. I guess it takes a engine failure for them to see there is an issue. I have a 100k warranty so I hope i'm covered
  #34
Old 12-19-2007, 06:40 AM
miktvk miktvk is offline
Gallery
that's ridiculous. not normal. my dealer has confirmed that there is indeed something not right, and the regional tech rep has been summoned from new jersey.
'07 MINI Cooper S, Mellow Yellow
'01 BMW 530i
'02 BMW 540iT Sport-the heavy metal
  #35
Old 12-19-2007, 08:28 AM
misslindsey misslindsey is offline
Gallery
Lewis made a HORRID noise yesterday as I went to leave from work. Surprisingly, this was one day that I had driven to lunch, so he only sat for about 4 hours out in the slightly below freezing weather. It was awful, sounded a lot like that video, but went away after a couple minutes. I'll give anything an off day, but if he does that more I'll be calling the dealer to complain of that and the loud ticking (louder than injector solenoids should be) he makes all the time.
  #36
Old 12-19-2007, 12:47 PM
prb44t prb44t is offline
Gallery
I took mine into Classic MINI and they just reported back that the sounds are normal. I asked if its a normal sound why doesn't it sound like that every time I start the car? Why does it happen when the car is cold and outside temps are cold? Why didn't this happen when I got the car in early March and it was still cold then? He said he would ask the tech and get back to me. They left me a voicemail a few hours later saying the car was ready. But no explanation. Not sure what to do now? I'm no expert, but that sound can't be normal.
I had the car at a local shop that specializes in BMWs and MINIs (Koala Motorsports -- Brett Anderson) which I highly highly recommend. He was working on the lowering kit for mine. And when I was picking the car up he remarked why does your engine sound like death metal when starting? He said take it in immediately, it doesn't sound normal.
What do you do if the dealer says its normal? I told them that the forums are littered with this issue, and they said we prefer the advice of a tech vs. a forum.
1982 RHD 998cc Auto Classic Mini
Previous --2007 MCS, Laser Blue Metallic
  #37
Old 12-19-2007, 07:24 PM
msh441's Avatar
msh441 msh441 is offline
Gallery
Quote:
Be polite... but persistant.
If it... no, WHEN it does it again, set up another service appointment.
If you have the opportunity to video/audiotape the issue on start-up (cameraphone?), try that. Play it for the dealer and see what they say. Mine was unable to replicate the problem initially, either. The one time it was there and it did it, though... they kept it for another week trying to figure it out. Thats when the cam chain tensioner was replaced and it's done it once (ever-so-briefly) since.
Again, your attitude will go a long way. Polite but persistant.
Founding member of R56 Anonymous. Now repeat after me: "Hello.
My name is ____. I'm a driving enthusiast... and I still like the R56!"
  #38
Old 12-24-2007, 10:32 AM
matty125's Avatar
matty125 matty125 is offline
Gallery
Quote:
Originally Posted by miktvk View Post
Ah jeez, this problem hit my car big time just this week, 2200 miles. Checked here found a few posting on same cold-start death rattle, went over to Mini2, found this>>
http://www.mini2.com/forum/2nd-gen-f...when-cold.html
252 messages in one hair-raising 13-page thread, multiple sound clips included. I didn't even bother searching for others. Gonna call the dealer this week. Very dissappointing.
I'm bummed.
Mine does this when really cold, until its warm. I havent searched out the cause, but I thought it was the heat sheild?
Only losers say "Winning isn't everything."
  #39
Old 12-24-2007, 11:47 AM
Gallery
I got mine back on Saturday. They changed the VANOS Solenoid valve. They said it was sticking and that caused the problem. It wasn't cold enough until this morning to test, but today when I started the car the sound was back. I guess it will be going back soon.
  #40
Old 12-24-2007, 05:17 PM
msh441's Avatar
Gallery
Mine goes in Thusday for a Friday appointment.
BTW - I have someone from MINI calling me about a post I made in the Owners Lounge under Technical Updates about this very issue (http://on.miniusa.com/topic/Technical-Updates/Rattling-R56s-On/700004819) . Of course, being the Owners
Lounge... no one else ever replied. Might be worth others logging in and posting their experiences as well? Just a thought.
  #41
Old 12-25-2007, 05:23 PM
kfmuller kfmuller is offline
Gallery
Add my name to the list. I haven't driven my 2007 MCS for about a week and a half. I park in an underground garage in Dallas. The last week we've had a few days at or just below freezing. I started the car this morning and it made the horrible clattering noise. It sounds like a fan is rubbing against some part or the valves, but nevertheless this shouldn't be classified by the dealers as "normal".
By the way, my car is a May 2007 build w/ 1600 miles on it.
  #42
Old 12-26-2007, 08:58 AM
Gallery
I posted on the owner's lounge too. Who exactly contacted you from Mini about it and what did they say?
  #43
Old 12-26-2007, 03:41 PM
msh441's Avatar
Gallery
A rep from MINI Customer Care (or somthing like that). Been playing phone tag all week. Should have more details tomorrow.
  #44
Old 12-26-2007, 09:33 PM
checkercoop's Avatar
checkercoop checkercoop is offline
Gallery
yeah that sound cannot be normal...i do feel its possible that it could be with the variable timing...maybe a program bug or error? (maybe with a mixture of cold air and cold engine the sensors send a bad message to the engine and the variable timing is changed?) i know if you get your self going at say 5 mph and try and go in 2nd or 3rd (so the end is pulling around 1000 rpm) and you give it gas you can duplicate that sound (variable timing is dumbing a lot more gas to get the car going, but the rpms are so low that it struggles)
11 MCS | EG/B | manu | carbon black interior | leatherette | MINI Connected with NAV
Good By: "Check" MC | PW/B | stick | cream line interior | piano black interior | checkered cloth sports seats | fog lights | anthricite headliner | JCW checkered floor matts | JCW Grill | Vinyls | Blackout chrome PW Peerage # 1988
  #45
Old 12-27-2007, 01:54 AM
minicobra1's Avatar
Gallery
this morning it was 34 degrees in Palm Springs. I was headed back to L.A. and the car felt really slugish for the first 20 minutes or so. I didn't get the turbo prop diesel metal sound, but was anticipating it. This really takes the fun out of driving the car, or at least starting it.
  #46
Old 12-27-2007, 08:24 AM
Gallery
It was about 35 here this morning in Cleveland and I got the sound though for a shorter period of time and less pronounced. From my experience there seems to be a correlation between outside temp and duration/volume of the horrid metal on metal sound. Anyone else see the correlation?
  #47
Old 12-27-2007, 09:21 AM
sequence sequence is offline
Gallery
Boy I hope someone figures this out pretty soon. Question? when this happens, what does the exhaust look/smell like? This could offer a clue.
TSBs are also issued when there is an occurence of problems that are previously not on record. For example when I first started experiencing problems with my LOUD dash center-pin rattle there was no TSB, but after 2 visits to the dealer with the same issue over a 6 month period, one finally came out and the problem was fixed.
Been thinking about an R56 once the warranty on my 05 S runs out, but hearing all this I'm not so sure; glad my S has the old, low-tech iron block motor w/o all those VVT bells and whistles. It is the part of my car that's proven itself reliable beyond compare.
I say, boy, you dont seem to be apprehendin' the general gist of what I'm tryin' to convey here. Maybe you oughta take a second, let your head catch up to your tongue before it gets all sunburnt. That was a joke, son, I say - a joke! Nice boy, but he's about as sharp as a sack o' wet mice.
09 MCSa JCW
  #48
Old 12-27-2007, 03:18 PM
msh441's Avatar
Gallery
Mine went in for service today... accompanied by a detailed description of the problem and a half-dozen videos on a CD. That way I'll hopefully avoid the one-start "sounds normal to us" responce.
Got a Cooper convertible as a loaner and some indication that they would want to keep my car "'till this is sorted out once and for all".
Hope everything works out (crossing fingers).
  #49
Old 12-28-2007, 10:33 AM
Gallery
Got a loaner eh? Nice, I got nothing.
Car still sitting there, going on 3 weeks now. All I know so far is they put in a new tensioner, per rep's instructions. Since I've heard nothing, guess it was a no-go. 15 business days out of service=invoke Mass lemon law. Correction, they get 7 days after the initial 15, providing them 'one final repair opportunity'
Wasn't expecting this. Sad.
'01 BMW 530i
  #50
Old 12-28-2007, 10:39 AM
Gallery
3 weeks? Are they communicating as to what they are doing? or did they do the tensioner and nothing else? They are picking mine up next week. I assume they are dropping off a loaner. Guess I will find out.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
