Clutch Replacement
Old 01-19-2008, 06:29 PM
GregO's Avatar
GregO
GregO is offline
Clutch Replacement
The clutch has been replaced (12000 miles, 2006 MCS). As reported before, the new clutch feels "lighter", but what bugs me most is that about the first 2 inches of pedal travel are super soft before the pedal hits what I'd call normal resistance. Is this normal or could it be adjusted/tightened?
Thanks. Greg
Old 01-19-2008, 06:31 PM
tazio's Avatar
tazio
tazio is offline
You smoked a clutch in 12k miles? Nice.
Old 01-20-2008, 05:50 AM
TLMCS05's Avatar
TLMCS05
TLMCS05 is offline
If possible, park your car facing up hill. put something between the clutch and the seat that will keep the clutch depressed all night. You may have air bubbles in there and this will force them back into the res. Cured mine.
Old 01-20-2008, 06:38 AM
GregO's Avatar
GregO
GregO is offline
thanks
Thanks! I'll try that. Greg
Old 01-20-2008, 01:58 PM
JAGFIXER's Avatar
JAGFIXER
JAGFIXER is offline
There is a bleed nipple on the clutch slave cylinder.
Old 01-21-2008, 06:47 AM
GregO's Avatar
GregO
GregO is offline
slave cylinder bleed
Is this something a monkey could handle or should I have it done by someone else? I don't want to go dorking around with this if it might not be a good idea.
Thanks. Greg
Old 01-28-2008, 08:36 PM
Goondockjeff's Avatar
Goondockjeff
Goondockjeff is offline
Im just over 12k on my S and have noticed the clutch starting to go too. Hmmmm. Going to upgrade soon I think, and throw in a quaife while im at it.
What clutch did you go with?
Old 01-31-2008, 07:17 AM
second to none's Avatar
second to none
second to none is offline
^^ I am assuming he was under warranty. I would be weary of letting the dealer change my clutch again. I blew a tranny at 21-22k and they changed the clutch because it was soaked in gear oil. I struggled with that dealer because they didnt want to warranty it, and then did a crappy job (stripped my airbox screws, had greasy hand prints everywhere, and hammered the hubcentric ring to put the axle in, causing the wheel not to fit, which they forced on with an impact gun). I know for sure they didn't change the flywheel, and definetly didn't resurface it.
Old 01-31-2008, 10:27 AM
markp's Avatar
markp
markp is offline
Rush "Roll the Bones"
If I'm not mistaken you can't resurface a mini flywheel..That's why all replace when changing the clutch.
Old 01-31-2008, 10:44 AM
sequence's Avatar
sequence
sequence is offline
you are right. No U can't.
Old 01-31-2008, 10:50 AM
MiniMacPR's Avatar
MiniMacPR
MiniMacPR is offline
To the OP: Did you solve the issue? I think I might be experiencing the same thing...
Old 01-31-2008, 10:58 AM
ChrisMCS04's Avatar
ChrisMCS04
ChrisMCS04 is offline
Peace Keeper
I had mine disinigrate in less than that!!!
I mean COMPLETELY DISINIGRATE!!!
@10,89-miles
Not happy about it, but I had a throw out bearing go and BOOM! the rest went as well. It was not fun and the dealer was going to cover it in full under warranty and then the owner decided I drove too hard... It was not my driving style by any means. I take care of my car and it was the bearing.
Be ware of these they are made of.........what? Plastic?.....YES! Why in the hell would Mini do this??? Who knows...Just some advise to watch for.
Chris.
P.S. Don't let the dealer screw you like they screwed me...They decided that 50%/50% was satisfactory. My bill was $1,200+
I wanted one of Jan's Clutchmasters, but this is how my dad and I delt with it...should have went with a Clutchmaster instead...can't wait to build my turbo car and get rid of these S#it clutches
Old 01-31-2008, 03:31 PM
nixjosh2's Avatar
nixjosh2
nixjosh2 is offline
I was getting the chewie growl, took it in and having the clutch replaced under the extended warranty, glad I had that, Global said they are allowed one clutch change under warranty?????
Old 02-01-2008, 10:55 PM
AliceCooperWA's Avatar
AliceCooperWA
AliceCooperWA is offline
sounds like air in the system...you can also just pump the clutch a while. It should get better with use. They are "self bleeding" according to the haynes manual...although it only bleeds itself when there is just a little air. I had a release bearing melt one time...I would love to know why they use plastic!
Old 02-02-2008, 07:36 AM
GregO's Avatar
GregO
GregO is offline
new clutch
New clutch seems to be fine thus far, although we're only 1,000 miles into it. It was a dealer replacement, so can't tell you what parts/brands used, other than it was listed as remanufactured. Based on clutch performance thus far, I feel it was definitely the right move to have it addressed.
It's ridiculous that any new vehicle should have clutch issues, especially "performance" vehicles several years into production.
Greg
Finhead
105
08-14-2023 07:51 AM
eliseo1981
01-28-2021 02:45 PM
PrimePower
08-16-2015 06:29 PM
Powershift
08-16-2015 05:14 PM
Colt45Magnus
08-12-2015 06:43 AM
Quick Reply: Clutch Replacement
