Yellow engine light - full engine power no longer available
#151
Hi Folks - My daughter has had this same problem with her 07 S this winter and last. Its in the shop as we speak - picking it up this afternoon. Its been in a few times with same issue but this is the first time they have given her a reason ( which seems to be the frozen throttle valve problem ) and a solution that is being worked on by the BMW engineers ( in Winnipeg?) Service manager said they are working on a heated throttle valve replacement. Anybody else hear of this?? Hopefully get more info later!
#152
#153
Ok so after surviving the remainder of last winter without issues (my posts are on page 1 of this thread) and so far this winter with temps as low as -16 in the morning, my car does this to me this morning:
http://www.youtube.com/watch?v=VniVI806x-A
I drove the car acting like this my 5-6 miles into work today - it was EXCRUCIATINGLY slow and embarrassing- at each stoplight my car would oscillate and backfire and there was nothing I could do...
I still fall into the short commute distance but I haven't changed anything this winter so why would it be OK at -16 but NOT OK at +15????
Last winter I had the fix of a new throttle body and then went back in for the 'fix' of a new evaporator set up for the throttle body...
Obviously none of this is working... my MINI dealer didn't even want me to bring the car in... there isn't anything they can do...
I am really at my wits end with this... its just so disappointing
#157
If it is the turbo, then why would it only happen on a turbo MINI cooper S and not any other of the hundreds & thousands of turbo cars out there in the freezing cold Canada (e.g. Audi A3, A4, Subaru's, etc).
I'm still just completely amazed that this car passed a cold weather test...engineers are meant to run this thing in the freezing cold up north for month's on end before they successfully validate them.
Where did MINI/BMW validate the cold weather test?
It's stupid problems like this, that other car manufacturers have worked out the kinks in, which are damaging our resale value on the car.
#158
Update on removing the cold air snorkel......
Well, I have had more trouble with rough starts and sounding more and more like a diesel, and a few more instances of the CEL light coming on, and the occasional loss of acceleration power when the computer decides that it has a problem..... BUT I have not had any more instances where I have only been able to drive at 20 to 40 kms per hour. And mostly the roughness goes away after the car is driven for a few minutes at higher speed, even when the temps drop to -25 to -35 C. So, at least my mini S is running, if not well. We'll have to see how it goes for the rest of the winter.
I love my mini but I think that it is just about time to go shopping for something more reliable. EKG, I'm with you.... It would be great if BMW would buy the car back... But given that anything that I have forwarded to the manager of our dealership here has been ignored... I am not going to count on it.
#159
#160
Sorry haven't read the whole thread but it seems that these may help you guys.
Basically my mate had the turbo stop working, running rich, excess fuel consumption etc...as well as the timing chain (rattle) problem...has had a whole new engine fitted!
Anyhow, these are threads from MINI2 and 207 GTI forums....same engine you know! It appears to be a CAM timing issue..anyhow...hop they help
http://www.207oc.com/index.php/topic,1282.135.html
http://www.mini2.com/forum/2nd-gen-f...r-4300rpm.html
#161
You can add me to the list.......I was abit confused when it happened the first time at 0 degrees. Got the CEL, let it warm abit, shut it off, restarted and drove to work. Cleared the CEL with the scan gauge( probably should have written it down, I 'm sure it will happen again, based on what I have read here) I'll have to ask the dealer( 30,000 mile service and state inspection coming up)
#162
Update from Mini Winnipeg today (they have had my 07 MCS since Dec 18). Apparently the new intake manifold fix is not working, and they are waiting for Mini to come up with another solution. They have no ETA on fixing my car, and do not plan to give it back until a solution is found.
At least I have a rental that runs, and they have agreed to cover the additional insurance I have been paying on the rental.
I am almost ready to return the car and get something else. Any suggestions on an all season performance car to replace it with?
#163
boost gauge wouldn't move up at all. got out my car and felt the turbo and i didn't feel or sound like it was spooling up at all. and the oil would just be of lighter weight made for the cold.
#164
#165
Don't want to rain on your parade but I had the manifold replaced in December and still have the issue. And I believe the redesigned manifold is on all 09s by default, and I think I've seen some 09s pop up with the issue here on this board.
#166
#167
#169
Daughter got her mini back the other day from service - same old thing cleaned out throttle valve condensation - oil change because of water in oil ( that concerns me!) cleared fault memory and handed car back to her. Engineers in Winnipeg working on a fix...nothing yet! 2 years into warranty - second winter with same problem! Now it is becoming a safety issue for us. -25c in an empty parking lot after work at 3 in the morning and she has trouble getting the car running - limping home on the highway is not safe! We raise our concerns with dealership everytime we take car in and although they are sympathetic nothing has been done! Sorry for the rant - just a concerned parent.
#170
so, for those having this problem has Mini been changing the oil when or if there is water found in it?
I have an appt. booked mid Feb. for this issue again but the first time I took it in they didn't mention having to change the oil. I hope they do change it since it is probably common for Mini's having this issue. It has happened 3 more times since I have took it in the first time. But, I have been able to restart it hours after clearing the CEL and/or being able to drive it with the yellow CEL on.
#171
Had mine in three times in the last three weeks. They have changed the oil and filter every time (3 times in 500 miles). Dealer called today and wants me to bring it in next week to have the intake manifold changed. I'll give it a try, but I'm not holding my breath...
08 MCS, PW/PW, Sport, LSD, JCW tuning kit, Roof Racks, SGII
#172
Calminidad let me know what happens with yours. I spoke to the sales mgr on Thurs, and he was sympathetic. I told him my story, and he said "at least we are paying your lease payments while it is here though." I paid cash - so no.
I am rather remorseful about the car. Not only did I give them 30K for the car, they still have it!
My problem is now rather simple - if I want to sell the car, and get something that works in the winter in Winnipeg - is am stuck, because they have it, and won't give it back. Can't sell a car that won't run. I have asked the dealer to give me my options.
I will let you know what the "options" are. This car is making my Alfa Spider look reliable.
#173
Hopefully there is strength in numbers and BMW/Mini will realize the significance of the problem. Lets keep pushing the dealer to assist us in the fight.
#174
We haven't discussed a buy back from Mini yet but certainly would look into that if this problem isn't dealt with soon - My daughter would have a hard time getting rid of the car especially when the warmer weather comes around and she forgets about the cold weather problem but I would not want this continuing into next winter - she worries every time she gets into the car after work when it gets cold.
Service hasn't done anything to engine whenever it's in other than clean throttle valve as per Mini's recommendation - no mention of intake manifold change. I don't think they want to keep the car there for long as there probably isn't room what with all the others in for same problem. Mini Calgary only has one loaner car for servicing ( they offer a shuttle to and from dealer but thats kind of inconvenient when working ). Let me know if you all get anywhere with dealer. thanks
#175
