Engine Knock During Cold Start
The engine valves are noisy during cold start. The oil dipstick is half-full, but the valves are noisy for about 5 minutes after I start the engine.
The current temperature in Sacramento is the high 40's and low 50's. Is it normal for the MCS to be noisy normal under these weather conditions?
survey says as horrible as it sounds, its perfectly normal
https://www.northamericanmotoring.co...weather+starts
The rattley cold start some people are experiencing... the one that goes away after 1-5 minutes... has NOTHING to do with direct fuel inection . Trust me... if you car doest it on start-up... YOU WILL KNOW!!! It sounds HORRIBLE . Best place I've seen for vids and discussion is here:
http://www.mini2.com/forum/2nd-gen-f...when-cold.html
Just as a note off the beaten path. Direct injection does not need to be noisy. My other car has a direct injection based V6 and you cannot hear a single plink from it. Cold, hot, does not matter it is perfectly quiet. I have even raised the hood and tried to hear some noise and there is none.
Yet the Mini's direct injection system can be quite loud. Cold does seem to exacerbate the condition. Romi does indeed sound like she has a diesel engine on cold mornings.
The tapping sound is back during cold starts and it occurs when the temperature is below 40 degrees. It does not happen everytime, but when it does, I let the engine run idle for about 4 minutes before the sound goes away.
Is this really normal? Should I let the dealer check the engine? Is the cam tensioner really the cause of this issue as mentioned by one of our NAM members?
IMO, get it to the dealer now.
I dropped-off my MCS at Niello of Sacramento last night. Niello mentioned that this could be the high pressure fuel pump which is not unusual with the 2007 MCS. I'm not familiar with these cars, but is that correct? If so, should MINI recall the 2007 MCS to replace these noisy high pressure fuel pumps?
As stated several times before... the common-rail direct fuel injection system uses electrical solonoids to spray fuel into the cylinders. So yes, it clicks away as the engine runs.
But no... it's not the sound owners are descibing in these cold start rattle threads. Go over to MINI 2, or the thread here on NAM ( https://www.northamericanmotoring.co...d.php?t=121761) where I posted the videos, and see what we're talking about. Then lets hear your dealer say it's normal.
The OP, and all but one or two posters here have the MCS.
It must be too early for me.
Reason this happens is because the valve lifters "bleed down" from no oil pressure after the car sits for a while. Since these engines have automatic valve lash adjustment, the tappets (lifters) need oil pressure and the only way they get it is from the engine running. It's nothing to worry about, just turn your stereo up a little louder until it goes away...
Considering 1) It isn't happening to every car 2) Frequency and duration increases over time and 3) Low oil means decreased lubrication and therefore increased wear and tear on moving parts... I would most definately worry about it.
A stuck valve or two and an inoperative cam chain tensioner can do some serious long term damage to the head, cam chain and if the chain wears abnormally and breaks, there goes the valve train and heads. So just turning up the stereo and ignoring the issue is a very, very bad idea.
