Blue light oily fluid?
Old 11-04-2008, 01:47 PM
lawmann's Avatar
lawmann
lawmann is offline
Coordinator :: Middle Georgia MINIs
Cassie had this same issue at 27,000 miles. Global Imports repaired it for me. I figured I should go ahead and purchase a new thermostat housing and thermostat (which comes with the gasket). Cassie now has 46,566 miles an no leak, but if it redevelops I am prepared. The procedure to change out the thermostat and housing is rather simple.
  #102
Old 11-05-2008, 08:21 AM
PenelopeG3's Avatar
PenelopeG3
PenelopeG3 is offline
Honestly, its not worth buying a gallon of coolant just to top off an inch or so of coolant in the reservoir. That small of an amount of dilution won't make any difference whatsoever. Just make sure you use distilled water (not tap water) and you'll be good to go. The dealer will top it off with coolant when they replace the part anyway.
  #103
Old 11-05-2008, 11:46 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
JIM_GRAHAM is offline
I have an 05 MCS w/ 38k miles that has "the leak". What is the warranty period that this is covered under? The 5yr 50k power train warrantee?
  #104
Old 11-05-2008, 02:56 PM
RudyT's Avatar
RudyT
RudyT is offline
Yes... although my warranty is a 4 year, 50k mile... still covered...
  #105
Old 11-05-2008, 03:02 PM
RudyT's Avatar
RudyT
RudyT is offline
Originally Posted by RudyT
I think you can add me to this infamous list...
Havn't driven the MINI in 4 days as it was stored in a Garage... Moved it out 10 feet out onto my driveway today where I left it all day. Tonight as I casually drove it back into the garage, I notice a greenish blue oily substance on the driveway... Checked the fluids and notice the engine coolant was below MIN. Not sure this is normal but I am guess at this point its the engine coolant...
After it sits in my garage now after an hour, no leaks to speak of. Not sure what to do at this point. Call it in to the dealership or keep motoring ?
As a followup..dealership diagnosed a coolant leak caused by a faulty thermostat housing and gasket. Replaceable under warranty... A tip to try, if your having trouble getting your MINI to reproduce the leak, is to lift the front end either by parking on an incline or using a lift and jack stands.
  #106
Old 11-05-2008, 05:04 PM
Camthewookie's Avatar
Camthewookie
Camthewookie is offline
I had this problem recently at about 36.5k miles. Same thing as above - bad t-stat housing and gasket.
  #107
Old 01-08-2009, 09:40 PM
bluzeke's Avatar
bluzeke
bluzeke is offline
Count me too as blu.
Sudden small blue puddle on garage floor equaled bad thermostat housing and/or gasket at 37K - covered under warranty.
(sidenote: mentioned recent sporadic "chewbacca" clutch noise and am also getting new flywheel & clutch per latest Service bulletin)
  #108
Old 01-09-2009, 03:53 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
Do you have any info on the service bulleten? Anything that covers a clutch and flywheel has me all ears!
  #109
Old 01-09-2009, 08:14 AM
bluzeke's Avatar
bluzeke
bluzeke is offline
Jim - here's the gist of it, poorly reproduced from this thread. This will be my 3rd clutch/flywheel replacement under warranty - kudos to my stand-up dealer. The first two were replaced because the Dual Mass Flywheel's were noisy (when an R53 sounds like an old Mercedes diesel - countless threads on the subject here) and as I said above, the latest when I mentioned the car was, with the arrival of cold weather, beginning to periodically emit the so called "chewbacca" noise on clutch release.
Good Luck - my sense from reading threads here on NAM is that some dealers are more likely to comply with the Bulletin while others may need a more of a "come to Jesus" meeting about it.
[FONT=arial, helvetica, geneva][SIZE=3]SI [FONT=arial, helvetica, geneva][SIZE=3]M21 04 08[/FONT][/SIZE]
[SIZE=3][FONT=arial, helvetica, geneva]Clutch[/SIZE][/FONT]
[/SIZE][/FONT][FONT=arial, helvetica, geneva][SIZE=3]September 2008[/FONT][/SIZE]
[SIZE=3][FONT=arial, helvetica, geneva]Technical Service[/SIZE][/FONT]
This Service Information bulletin supersedes SI M21 04 08 dated August 2008.
designates changes to this revision
[FONT=arial, helvetica, geneva][SIZE=2]SUBJECT[/SIZE][/FONT]
Howling Noise from Transmission while Engaging Clutch
[FONT=arial, helvetica, geneva][SIZE=2]MODEL[/SIZE][/FONT]
R52, R53 with W11 ( Cooper S, Cooper S Convertible) with GS6-85BG manual transmission
[FONT=arial, helvetica, geneva][SIZE=2]SITUATION[/SIZE][/FONT]
A loud howling can be heard from the front of the car when engaging the clutch and pulling away from a stationary position. The noise is more pronounced when the vehicle is cold, but weather and driving conditions do not have an influence.
[FONT=arial, helvetica, geneva][SIZE=2]CAUSE[/SIZE][/FONT]
Clutch release system
[FONT=arial, helvetica, geneva][SIZE=2]PROCEDURE[/SIZE][/FONT]
On a customer complaint basis, replace the dual mass flywheel, friction disc, pressure plate, release bearing and guide tube. In addition, the engine to transmission alignment dowels must be replaced. Refer to RA 21 21 500, Removing and installing/replacing clutch.
[FONT=arial, helvetica, geneva][SIZE=2] PARTS INFORMATION[/SIZE][/FONT]
Vehicles produced up to 7/2004
21 20 7 548 804
Dual Mass Flywheel
Clutch Kit
Guide Tube
Dowel
Vehicles produced from 7/2004
Part Number
Description
Quantity
21 20 7 548 804
Dual Mass Flywheel
Clutch
Guide Tube
Dowel
[FONT=arial, helvetica, geneva][SIZE=2]WARRANTY INFORMATION[/SIZE][/FONT]
Covered under the terms of the MINI New Vehicle Limited Warranty.
  #110
Old 01-09-2009, 09:35 AM
welshmenwillnotyield's Avatar
welshmenwillnotyield is offline
Echoing what others have written here, my '06 MCS [39k] started puddling that fluid. The dealer found it to be a faulty thermostat and gasket. they were replaced under warranty and nothing has appeared since.
  #111
Old 01-09-2009, 03:16 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
Thanks for the info. My MCS does not make the Chewbacca noise right now, but to get a free clutch I might have my wife hide in the back seat and make the noise while i'm out on a ride with the Service Advisor!
If the service departments workload is slow they just might go for it!
Thanks again...
  #112
Old 01-09-2009, 03:53 PM
yellowbritishrocket's Avatar
yellowbritishrocket
yellowbritishrocket is offline
oh i have the blue fluid too but its not the t-stat...its the heater hoses
  #113
Old 01-13-2009, 08:00 PM
a2coopers's Avatar
a2coopers
a2coopers is offline
rad flush
Just did a rad flush, had the t-stat housing checked and it was also leaking, had it replaced under warranty, 72K KM on the car, also had a main seal on the driveshaft leaking that connected to transmission, and the final thing from all my vibrations, the right muffler was found to have broken pieces inside possibly causing the vibrations at low RPMS, waiting for that on back order....
Car drives well enough but mainly I'm taking care of these small things before the warranty runs out...
  #114
Old 01-13-2009, 08:06 PM
dogdal24's Avatar
dogdal24
dogdal24 is offline
Same Blue fluid leak 32,000 miles. T-Stat and gasket replaced under warranty!
  #115
Old 01-20-2009, 01:24 PM
running4amini's Avatar
running4amini
running4amini is offline
Smurfed at 19,700 miles. T-Stat housing and gasket replaced under warranty!
Talked with the Service Manager and he said that the replacements parts were remanufactured so as to address the issue with the faultly gaskets in the housings. So hopefully this won't happen again in another 20K when I am out of warranty.
  #116
Old 02-02-2011, 01:25 AM
fatbysl's Avatar
fatbysl
fatbysl is offline
Just bought an 2006 mini cooper with 14000 miles. Noticed that it is leaking blue fluid reading these post looks like a thermostat housing/gasket problem. With the mini being 06 its probably out of warranty right? Hopefully this is an inexpensive fix since i have only had the car for 5 days.
  #117
Old 02-02-2011, 07:14 AM
crappie_fisherman's Avatar
crappie_fisherman
crappie_fisherman is offline
fatbysl,
Mine was the thermostat housing.
Mine is an '05 and was clearly OUT of warranty when I discovered this too...I brought it to the dealer and they fixed it under warranty...If I remember right they may have said this was a "silent" recall that they are fixing as they come in...but don't quote me on that...
Good luck and congrats on the car...14K miles...WOW...been pampered huh!!!...nice find!
Joe.
  #118
Old 02-02-2011, 07:40 AM
fatbysl's Avatar
fatbysl
fatbysl is offline
Not going to take it to a mini dealer closest one us 135 miles away and would have to go over a mountain pass. Do you think a local BMW dealer would allow the silent recall as under warranty. Thinking about doing it myself, but I know nothing about cars is it that hard to do.
  #119
Old 02-08-2011, 04:40 AM
Rocketman14's Avatar
Rocketman14
Rocketman14 is offline
I just bought a 2010 Cabrio. Have any of these models had the same leak? By the way, great forum! This is my first post as an official Mini owner.
  #120
Old 11-26-2012, 09:09 AM
Minibeagle's Avatar
Minibeagle
Minibeagle is offline
I have just confirmed this past weekend that my 2006 JCW Competition edition has the same issue (blue puddling liquid = coolant). I had checked the thermostat housing closely and could not locate any leak there.
I thought it was the power steering fluid for a while, but had that checked and it was fine.
What's even weirder is that I only seem to be getting pooling when the car is parked on an incline.
Looks like another peek may be in order
  #121
Old 01-17-2013, 11:27 AM
cmacattack's Avatar
cmacattack
cmacattack is offline
I have an 09 JCW with 53k miles on it. I noticed some steam from under the hood last night and some blue stuff leaking out the front of the grill. So i'm pretty sure the radiator produced a leak. i think it's cause it's been between -5 and +10 degrees F the last couple weeks. Getting to the dealership to top off the fluid reservoir (below the min line) is not a possibility. Anyone ever top off with something different? What did you use?
  #122
Old 01-17-2013, 02:39 PM
kazlot's Avatar
kazlot
kazlot is offline
You can use distilled water till you can get the proper coolant.
When you do add coolant be careful about what you use
as some brands are not compatible with BMW / MINI coolant.
Hope this helps...
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
08-19-2015 08:28 AM
08-19-2015 08:27 AM
Powershift
08-16-2015 05:14 PM
Quick Reply: Blue light oily fluid?
