MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
by mnypny
7,680 Replies, 268,122 Views
[Newb] I want a "smoother" ride
by Eleo
88 Replies, 2,644 Views
Advertisement
Thread Tools Search this Thread
Old 07-15-2007, 09:41 PM
DrkSilver163's Avatar
DrkSilver163 DrkSilver163 is offline
Feedback Score: 1 reviews
Send a message via AIM to DrkSilver163
Gallery
Cooling fan stays on long after the car is off...
Hey everyone,
I have an 04 MCS and after a relatively long drive the fan doesnt quit for a while after i turn the car off. It goes on a lot when it is idling, too. Any speculation as to if there is something wrong? Other MINIs dont sound like that., that ive heard at least.
Thanks,
Marco
R.I.P. Polo:
Old 07-16-2007, 05:30 AM
joey1320 joey1320 is offline
Feedback Score: 0 reviews
Gallery
check for coolant leaks, if you dont see any you may need a new assembly.
Old 07-16-2007, 07:49 AM
Rich.Wolfson Rich.Wolfson is offline
Gallery
Quote:
Originally Posted by DrkSilver163 View Post
Hey everyone,
Does it eventually go off? If it does it is probably normal. It doesn't happen every time I assume. But there was a problem with the fan assemblies that caused them to stay on and not go off until the battery drained. That problem did require a new assembly as the thermostat is not replaceable on its own. Mine was changed under warranty. That said, Artoo, blows the fans lots of times at idle and after a spirited run.
Rich
Old 08-19-2007, 06:01 PM
JRhea JRhea is online now
Gallery
Coolant Fans Running a long time
My fan started running run for five to seven minutes after I shut the car off. I solved my problem by adding water to the nearly dry reservoir. Now it's back to normal.
Old 08-19-2007, 06:36 PM
cmy cmy is offline
Gallery
Coolant sensor housing
This happened to me earlier this summer. The housing on the coolant sensor had become corroded and caused a leak. Not sure how many coolant sensors there are or where they are located, but I think it was near the thermostat.
Hope this helps.
Old 08-19-2007, 07:54 PM
element element is offline
Gallery
what resivoir did you add water to?? Coolant? Mine has always done this and never experienced any other problems..
Old 08-19-2007, 08:26 PM
Gallery
It hasnt been as prevalent as it was when it was hotter, but i havent looked into it at all. Ill check the reservoir...
R.I.P. Polo:
Old 09-12-2007, 07:25 AM
Discosmurf's Avatar
Discosmurf Discosmurf is offline
Send a message via AIM to Discosmurf Send a message via Yahoo to Discosmurf
Gallery
Hi - didn't want to start a new thread because I figured this is where my question would probably be directed.
Anyhoo, on Monday, I noticed that my 02 MCS's fan still had not shut off after a normal day of driving. (BTW - I drive back and forth on the beltway 5 days a week and deal with moderate to heavy traffic, if that can be taken into consideration.) However, I assumed that it would shut off after a while. It had done that before, where the fan would last for what seemed like forever and then eventually shut off. When I got in my car about an hour later (the fan was no longer running so, I assumed that everything was fine) the car would not start at all. We tried jumpstarting and turned out that the battery had 29 watts left out of 550 watts; so I ended up buying a new one. To make this a shorter story, I now have to disconnect and reconnect the battery in order for the fan to shut off and not drain the battery.
What does it all mean? Am I going to need a new assembly like you all stated here? Help, please.
MMC #193
- by COOPERation
Old 09-12-2007, 07:26 AM
Discosmurf's Avatar
Gallery
Oh, and p.s. my car has 104,800 miles :(
MMC #193
- by COOPERation
Old 09-13-2007, 11:57 AM
Speedwing's Avatar
Speedwing Speedwing is offline
Gallery
See this thread for fan stays on issues:
http://www.northamericanmotoring.com...an#post1020468
If ???? you can take apart the fan by seperating the shrouds ...RELAY, MAKE CONTACT, WHITE GREEN161360141229 is the part to replace. Otherwise it is included in the entire fan assembly.
Find the correct plug and you can turn the fan off without disconnecting the battery every time ..... until you get it repaired.
Speedwing
Motoring in HENDRX
2005 Purple Haze MC
Old 09-14-2007, 07:15 AM
Discosmurf's Avatar
Gallery
Thanks Speedwing.
I followed the link and several other links that gave a lot of useful information.
But, get this. Yesterday, after reconnecting the battery when I left work (mind you, it had been sitting for about 8 hrs) I drove in pretty heavy, stop-and-go traffic for about 1 1/2 hrs and when I got to my destination, the fan stopped. But, with my luck and being the worry-wort that I am, I disconnected the battery anyway.
I got home later and decided to give it a try and not disconnect the battery; this morning it started fine.
How weird is that!
MMC #193
- by COOPERation
Old 09-14-2007, 08:29 AM
Speedwing's Avatar
Gallery
Smurf .... Probably the new battery has now properly charged and has enough current to operate the fan relay. If this is true .... the fan was telling you to replace the bad battery!!! Heat can really kill a battery fast.
Keep an eye on it and good luck!!
Speedwing
Motoring in HENDRX
2005 Purple Haze MC
Old 09-14-2007, 11:03 AM
Discosmurf's Avatar
Gallery
Yes, I will! Thanks a lot!!
MMC #193
- by COOPERation
Old 01-05-2008, 03:55 PM
ToBFree ToBFree is offline
Gallery
I've been through this a couple times and yet to replace anything. I replaced the battery a few weeks prior to the first instance. It just seems that after a couple days the fan switches correctly again. I disconnected the battery just to see if letting the system reset after a few hours of no power will again get it back to working correctly. We'll see in the morning.
I've also considered installing a kill switch to make turning off the fan convenient. At least until I can get to replacing the fan motor.
Old 09-20-2008, 04:31 PM
StanMort's Avatar
StanMort StanMort is offline
Gallery
Deleted
Old 09-21-2008, 08:39 AM
Bajanmini Bajanmini is offline
Gallery
I also had this for 2 days,and then lots of click click click as in the relay and all works fine now that was a year ago if not more knock wood.
Old 09-21-2008, 08:42 AM
StanMort's Avatar
Gallery
Quote:
Where exactly is the relay? I can't seem to find it.
Old 10-02-2008, 09:08 AM
yuille36's Avatar
yuille36 yuille36 is offline
Gallery
I have an 03 MCS, and my fan comes on. This is normal when the thermostat hits a certain temperature, the coolant fan will come on. It's no big secret. But it shouldn't stay on for an extended peiod of time, to where the battery drains excessively. My fan kicks on, and runs for about three minutes or so, then shuts off. The next time, it does its thing, I will check my coolant level. I beleive a low coolant level will cause this, because the engine is running a little hot at that point. But my temperature gauge, registers normal and that's weird. I know about cars, and if a coolant fans runs, then your temp gauge should register it. But hey mini's have alot of quarks.....Just my two cents.
Old 10-02-2008, 09:14 AM
frenchie's Avatar
frenchie frenchie is offline
Gallery
Quote:
The temperature gauge is non linear on the MINI; it will remain in the middle as long as the actual temp is in the expected range, as soon as the temp gets outside of the acceptable range the gauge will shoot to the maximum setting without any hesitation. Although its a gauge, it behaves like an idiot light.
In the abundance of Water only the fool is thirsty!
Old 10-02-2008, 06:43 PM
Gallery
Yuille36, also remember the cooling fan reacts to the A/C system pressure, not just on coolant temperature. When it runs excessively, like more than a few minutes after turning off the vehicle, the system is broke and needs fixed. As it starts to fail, it can be a intermittent problem at first, but it will eventually fail for good. Three minutes is not really excessive, but more like normal dependent upon the conditions.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
