R50/53 Things You Didn't Know About Your MINI
Old 02-11-2006, 12:08 PM
Newdl's Avatar
Newdl
Newdl is offline
I am sorry to disapoint everyone who opens this and is looking for a list of things they didn't know.
I got an Idea as I was reading the manual to my dad's new HUMMER. What are some things that most people do not know about their MINI? Intersting little bits of information, odd facts, interesting tricks....LIST EVERYTHING YOU KNOW THAT YOU THINK SOMEONE ELSE MIGHT NOT!!!!
ShoogyB (02-05-2020)
Top Answer
02-11-2006, 05:27 PM
Rawhyde's Avatar
Rawhyde
Rawhyde is offline
The key recharges its transmitter when it's in the ignition switch on 05 and newer.
The UNLOCK button when held in will roll down all the windows and open the sunroof unless it has been de-activated.
The glovebox is refrigerated.
When you initially turn on the headlights, they'll be on low beam regardless of how they were when last turned off. The foglights are likewise off.
The controls on the automatic A/C are shaped like the MINI wings.
The annoying self-locking doors can be de-activated.
Daytime running lights can be programmed on or off per the owner's wishes.
When you activate the defroster, the rear defroster comes on as well.
There is a "pull ring" tucked under the rear seat to open the boot if there is an electrical failure.
There is a little toolkit included with the MINI.
There is a little tool to manually close the sunroof in case of an electrical failure.
The interior lights (or any other accessory) switches off after 15 minutes with the key off to prevent killing the battery.
The brake lights don't work without the key in the ignition.
The radio may turn off when you turn the key off, but you can turn it right back on without the key in the ignition.
The rear parcel shelf is designed to rest right behind the front seats upside down when it is removed from it's normal place.
There is an emergency release for the fuel door in the portside storage cubby hole in the boot.
All wipers can be lifted off the windshields, and they'll stay in the up position to keep them from freezing to the glass.
If parked with auto wipers ON, they'll be OFF when you start the car the next time. You must turn them off then back on to use them. (In case the wipers freeze to the glass)
Are these the types of odd facts you were looking for?
Rawhyde
Old 02-11-2006, 05:27 PM
Rawhyde's Avatar
Rawhyde
Rawhyde is offline
Rawhyde
The following 11 users liked this post by Rawhyde:
ApexSpeed (06-22-2018), cdemarco4 (05-02-2018), Chris In Milwaukee (07-28-2020), dkdzyn (12-12-2017), enimini (02-07-2018), fastjohnny (03-13-2019), Jmouse (05-29-2021), MCS@2005 (06-27-2023), mfurey75 (06-27-2022), Nancy WC (07-19-2019), Vitruvius (09-09-2019) and 6 others liked this post. (Show less...)
Old 02-11-2006, 06:03 PM
gokartride's Avatar
gokartride
gokartride is offline
Right...all that popped to mind was soft paint and windshield glass. Wasn't sure if we need to go down that road though.
Old 02-11-2006, 06:13 PM
MINIclo's Avatar
MINIclo
MINIclo is offline
7th Gear Gal
Oooh....I didn't know this one....very cool!
The following 3 users liked this post by MINIclo:
DCWake (08-02-2022), Lacey Cross (05-02-2020), mfurey75 (06-27-2022)
Old 02-11-2006, 06:51 PM
Kentiki's Avatar
Kentiki
Kentiki is offline
Just learned that in a convertible, if you lock the doors with the key in the actual lock (i.e. not from a distance) and hold the key in that position, the top and all windows will go up! Very slick.
Old 02-11-2006, 07:00 PM
mbabischkin's Avatar
mbabischkin
mbabischkin is offline
Does it in a hardtop too...
Old 02-11-2006, 07:05 PM
1nf3rn0's Avatar
1nf3rn0
1nf3rn0 is offline
The dealership knows how fast your car has been. They know all. They scare me.
The following 2 users liked this post by 1nf3rn0:
greenbuggy (11-24-2018), ttawfik3 (07-21-2022)
Old 02-11-2006, 07:08 PM
Android993's Avatar
Android993
Android993 is offline
Also, the dealership knows where your wallet is. Now that is really scary
Spyder192 (05-24-2022)
Old 02-11-2006, 07:24 PM
bamatt's Avatar
bamatt
bamatt is offline
My salesman told me it would do that but it mega drains your battery & that I should only lower or raise the top with the Mini running
Old 02-11-2006, 07:28 PM
umberto's Avatar
umberto
umberto is offline
RAWHYDE.....having a hard time picturing about that rear parcel shelf....is that with both rear seats folded down, where does that rear parcel shelf go?
Old 02-11-2006, 07:44 PM
89AKurt's Avatar
89AKurt
89AKurt is offline
I didn't know MINIs are a great ice-breaker with the ladies.
Old 02-11-2006, 07:53 PM
SB's Avatar
SB
SB is offline
That's cool about the rear parcel shelf. I've done this and I never thought that it was actually engineered to work as good as it does. I just thought it was a coincidence.
One I heard about recently and tested was the key recognition feature. With the driver door open, wave the key by the ignition switch and you will get a confirmation ding sound.
Old 02-11-2006, 08:25 PM
umberto's Avatar
umberto
umberto is offline
just went down to my car to play around with the rear parcel shelf...I see...that is pretty cool...I never knew that
Old 02-11-2006, 08:30 PM
MR ECON's Avatar
MR ECON
MR ECON is offline
If you touch the key to your chin or cheek while pressing the unlock button, the key will unlock your MINI from a much greater distance.
BRG_R53 (02-21-2020)
Old 02-11-2006, 08:42 PM
K9MINI's Avatar
K9MINI
K9MINI is offline
If you buy a MINI and say to yourself " I am not going to Mod this car" you will soon be selling off everthing including the kitchen sink to fund your new addiction. Oh I am sorry this is for "things I should have known better about" thread.
The following 6 users liked this post by K9MINI:
2mAn (03-14-2020), Andrew Yorkshireman (08-21-2020), BRG_R53 (02-21-2020), Crazyfool.MD (04-10-2022), DCWake (08-02-2022), Project_Mini (01-01-2021) and 1 others liked this post. (Show less...)
Old 02-11-2006, 08:46 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
That it's faster than a GTO
Jose Bermudez (04-22-2020)
Old 02-11-2006, 09:06 PM
Johnna's Avatar
Johnna
Johnna is offline
Nice list Rawhyde! I learned a thing or two!
Old 02-11-2006, 09:19 PM
Johnna's Avatar
Johnna
Johnna is offline
Rawhyde
Which tool and how do you work it?
Wipers up a little or all the way up?
Old 02-11-2006, 09:23 PM
Paul's Avatar
Paul
Paul is offline
The eye glass slot in the glove box is in the form of the MINI logo.
The factory radio will always restart at a reasonable volume level, regardless of how loud it was when the MINI was turned off.
DCWake (08-02-2022)
Old 02-11-2006, 09:25 PM
Paul's Avatar
Paul
Paul is offline
I think it's in the tool kit in the boot.
Old 02-11-2006, 11:18 PM
BostonMarkC's Avatar
BostonMarkC
BostonMarkC is offline
That rear parcel shelf tip is life-altering...no longer will it risk getting crushed by all the cargo when I leave it in the bottom of the boot and load up. What a clever design!
Old 02-11-2006, 11:22 PM
Rawhyde's Avatar
Rawhyde
Rawhyde is offline
It goes where the rear seat passenger's feet should go. The cutout for the rear wiper motor mates up with the hump in the rear floorboard that provides clearance for the exhaust.
The tool for closing the sunroof is in the little toolkit. Kinda shaped like a squared off S. You remove the front reading lights (clock on the pre 05's) and there's a place for it there. It's in the manual.
The wipers stay up if lifted all the way up.
One more...
There is an adjustment for the aim of the foglights. It is a white plastic allen screw. Look straight down behind the bumper. My MINI's foglights are MUCH better after I aimed them. I know there's supposed to be low, but mine were too low. Counterclockwise to raise.
Old 02-11-2006, 11:58 PM
Motor On's Avatar
Motor On
Motor On is offline
Okay don't know how common this knowledge is so
If you press and hold the trip button before turning the key you can acess the on board computer
your seat will go back to the original postion when slid forward using the outer releases
The ECU is held in place by the airbox on an S
If you unplug your ECU long enought the sunroof open and the windows go down
The change holder is the same shape as the gas cap on an S
Your vin is on thw window, door sill and in the engine bay The side refelectors are only on US cars
The shift **** doesn't screw on
Even if you don't have the OBC the tach display still comes with the avg, kph, mpg, range displays built-in
The gas pedal has its BMW part # written on it
The car was designed to be slighty off balance so that it was closer to 50/50 wieght distribution with a driver
It has equal lenght driveshafts to prevent torque steer
There is a slot just foreward of the dirverside rear wheel that one can hide a key in
reseting the ECU removes 1 mile off of the odometer
The car will protect it self from exceeding redline except when down shifting do to rapid increase in revs
redline can be moved through software adjustments
DCWake (08-02-2022)
Old 02-12-2006, 01:28 AM
Wonderdrug's Avatar
Wonderdrug
Wonderdrug is offline
If you have a car with automatic climate control, you can change the
temperature display from Farenheit to Celcius (and back again):
pre-2004: Hold down the "Auto" button for a few seconds.
2004 onward: Depress the AC button and the footwell fan button together.
DCWake (08-02-2022)
Old 02-12-2006, 05:11 AM
DaCrema's Avatar
DaCrema
DaCrema is offline
Mike, Mike, Mike....
You have been in Cali to long. Only on the left coast does the hard top go up when you lock the doors. Every where else it stays in place .
You need to come back to the right coast. We will take car of you.
Quick Reply: R50/53 Things You Didn't Know About Your MINI
