R60 :: Countryman Talk (2010-2015) R60 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
Sponsored by: DashLynx
R60 Driving Lights install instructions
Old 06-29-2016, 10:35 AM
Vader-S-All4's Avatar
Vader-S-All4
Vader-S-All4 is offline
Has anyone attempted to personally install driving lights on their Countryman? I picked up a factory set with the grill, all wires, and switches... Checked with my local dealer about install cost, and about S#@T myself... I am very handy and do all my own normal service work. (I.E. brakes / oil service, ect.)
What I am wondering is if there is an instruction guide out there... I looked around, but could only find something for the R56...
Help anyone???
Old 06-29-2016, 11:23 AM
TWISTER's Avatar
TWISTER
TWISTER is offline
ECSTuning (07-02-2019)
Old 06-29-2016, 01:28 PM
Vader-S-All4
R60 driving light install
So Im guessing the install is the same whether it is for an R56 or and R60?
Old 06-29-2016, 02:07 PM
TWISTER's Avatar
TWISTER
TWISTER is offline
yep!
Old 06-29-2016, 05:17 PM
dpike's Avatar
dpike
dpike is offline
flipping thru the install instructions... did they redo these so they come on with the regular headlights now ? mine one work with the high beam and my switch is just a single on/off rocker.
Old 06-29-2016, 05:18 PM
TWISTER's Avatar
TWISTER
TWISTER is offline
It all depends on how you wire it. You can have it one way or the other
Old 07-03-2016, 03:00 AM
devilmotorsports's Avatar
devilmotorsports
devilmotorsports is offline
Word of warning, pay close attention to how your Foot Well Module is orientated. Old versions of the install instructions are upside down. I ran into that problem and it made for quite the headache. See attached photos, look at the direction that your wires are coming into the module, note the location of the X14261 harness in each, in my car 261 was on the bottom.
Attached Thumbnails Driving Lights install instructions-rightway-round.jpg   Driving Lights install instructions-upside-down.jpg
Old 07-04-2016, 06:37 AM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
this is the 'legal' way and the instructions must do it this way. The secret is the trigger wire A1
this wire controls when the lights can come on. It connects to the BRIGHT ON lead (which is why the connection point is different for halogen and xenon lights). Only when this wire is hot can the DLs come on.
If this wire was connected to the low beam on, or an always on ... you get the idea (simplified explanation btw)
Two concerns:
This works fine for simple DL installs. The factory kit is NOT a simple install ... it is more complicated with the auto reset functions etc {and why the kit is $$ and install $$}
(a simple install would be to just wire and on/off switch with one relay. diagram for comparison:
A legal install moves the wire from the battery to the switch to be bright on to switch ... so the switch is only hot when brights are on.)
Some states check for 'legal' installs during annual inspections. IF your state does such installs you might want to ask around.
If you want more help PM me. I've installed severaL sets for folks, simple wires and factory kits.
Old 07-04-2016, 01:30 PM
TJANK's Avatar
TJANK
TJANK is offline
Agreed the instructions are opposite. My grey wire was the lower module but the upper set of pins to attach to. Driving Lights install instructions-image-4209811096.jpg Driving Lights install instructions-image-4292880741.jpg
Old 07-29-2016, 04:41 PM
jd72277's Avatar
jd72277
jd72277 is offline
Glad to see this thread. I just got a Countryman S All4 Wednesday after an 8 year gap in MINI ownership! This will likely be the first mod I do.
Old 01-02-2017, 10:55 AM
voicekiller's Avatar
voicekiller
voicekiller is offline
Thinking about this mod. It is worth getting the grill and bracket (#63132241489) or is it just as easy to use the stock grill and just order brackets?
Thanks,
Chris
Old 05-30-2019, 05:02 PM
dabbch's Avatar
dabbch
dabbch is offline
driving lights
My Mini Cooper 17 convertible.
One driving light , on the passenger side , keeps flashing.
help.
Old 05-30-2019, 05:55 PM
dmath's Avatar
dmath
dmath is offline
Is it fixed interval flashing or more intermittent like a loose connection?
Old 05-30-2019, 06:35 PM
dabbch's Avatar
dabbch
dabbch is offline
Flashing passenger side driving lamp
It’s more intermittent-
i called the company they said the red wire should be run to the fuse box Acc-
i have no idea what that means-
i had them professionally installed
they say it’s a bad light-
any help is appreciated-
Old 06-30-2019, 07:42 AM
MReiland's Avatar
MReiland
MReiland is offline
Question, I have a 2016 with Xenon, I put A1 into pin position 4 in X14260 (gray, there was nothing in that position. ). I have everything wired but A1 never goes +12 with lights on and high beams on.??? Does it need any dealer programming to activate this pin?
Old 06-30-2019, 01:58 PM
MReiland's Avatar
MReiland
MReiland is offline
Uggg, was following the instructions above which I couldn't get to work. Found a different set for R60 with Zenon, A1 wire has to attach to pin 41. Oddly, this one attached doesn't show the switch? Anyways it works now, didnt with wire in pin 4. Changed out the bulbs to CREE LED since I had the halogen housings. Perfect match color temp with Zenon. Only big disappointment was that MINI had put security screws on the bulb holders... why mini, why? No problem, had a full set of security bits.
simpsoap
03-25-2016 07:24 PM
R53Minicoop
03-13-2016 09:59 AM
cdrober
17
12-01-2002 01:22 PM
drstevenj
08-08-2002 07:14 PM
Verruckt
07-23-2002 07:58 AM
Quick Reply: R60 Driving Lights install instructions
