R60 :: Countryman Talk (2010-2015) R60 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
Sponsored by: DashLynx
R60 Blow off Valve
Old 02-16-2016, 05:55 AM
wlambertr60's Avatar
wlambertr60
wlambertr60 is offline
Blow off Valve
Hey fellow r60 owners. Has anyone thrown a forge dump vaulve or adapter or recirc valve? Been talking to a few people and they say the bov won't work and might throw me into limp mode. But shouldn't the recirc forge valve work?
Old 02-16-2016, 10:01 AM
devilmotorsports's Avatar
devilmotorsports
devilmotorsports is offline
I have the forge atmospheric adapter and no cel. Can't say I'd recommend it though, its a pain the *** to install and you can't hear it in the car. So really you'd be installing it for everyone else's listening enjoyment. I can't say that it help performance all that much either. Some have noted faster Turbo recovery times but I can't say that I've noticed. Im thinking of selling it and moving to the forge recirculation valve, I heard good thing about it, and since I'm considering getting a manic ECU tune it will do better with higher boost pressures. PM if you are interested in a used atmospheric adapter
Old 02-16-2016, 10:05 AM
wlambertr60
I actually found a forge recirc valve that I'm getting for 80$ the guy didn't get to use it when he bought it for 160.
Old 02-16-2016, 10:06 AM
devilmotorsports
That's a total score
Old 02-16-2016, 10:07 AM
wlambertr60
Rigghhtt?? I'm buying it this weekend. How am I going to install this? Cause I have to tap into the factory wiring harness right?
Old 02-16-2016, 10:12 AM
JuanTheHuman's Avatar
JuanTheHuman
JuanTheHuman is offline
http://www.waymotorworks.com/forge-blow-off-valve.html
Hey LAMBERT,
I installed this Forge Recirc Valve and I am very happy with its sound & performance. Contrary to what others have mentioned, I believe the sound is very noticeable, both inside and outside the cabin. Additionally, the OEM BOVs are notorious for getting dry/heat rotted and cracking, which could cause catastrophic turbo failure. And finally, if you are planning any considerable engine mods in the future, you WILL need an upgraded BOV to deal with increased pressure.
It is a little on the expensive side, but I found this kit to be a perfect Plug-n-Play OEM fit and has worked with zero problems and no CELs.
Drive Safe & Drive Often. Rubber Side Down. Over & Out.
Old 02-16-2016, 01:24 PM
wlambertr60
[QUOTE=JuanTheHuman;4175893]http://www.waymotorworks.com/forge-blow-off-valve.html
Hey LAMBERT,
Drive Safe & Drive Often. Rubber Side Down. Over & Out.[/QkUOTE]
Awesome :D finally someone with the recirc valve! I'm glad you like it.I'm buying mine this weekend for 80$ im so excited!!! Would you mind putting up a video of how it sounds?
Old 05-16-2016, 06:39 PM
pvtryan478's Avatar
pvtryan478
pvtryan478 is offline
Hey guys. I recently installed the Forge Recirc valve in my GP2. It's installed correctly and everything but makes no sound. Some of you are saying it makes a sound but I got nothing. Any feedback?
Old 05-17-2016, 07:04 PM
devilmotorsports
Be very careful, if you don't have any sound then its likely not working and can be quite bad for your turbo!
Did you get it new or used? (might need a rebuild)
Is it recirculating or atmospheric? (so we can tell you how loud you should expect)
What color spring is in it? (if it's too strong it will prevent it from opening)
For reference:
Valve Spring color coding: Green - 5-15 PSI, Yellow - 15-23 PSI, Blue - 23-30 PSI, Red - 30 + PSI.
Old 05-17-2016, 07:42 PM
pvtryan478's Avatar
pvtryan478
I bought it used with low miles and seller said they had no prior issues with it. It's the Forge recirculating valve. I'm not sure the spring color. It came with two and the red one is still in the box. What do you think the issue is?
Old 05-17-2016, 07:58 PM
devilmotorsports
I think the spring that is installed spring is too strong, assuming everything is installed correctly, that's what happened to me. Pull it apart and see what color spring is in it. The previous owner could of be running higher boost pressures than you, so no issues for him might mean headaches for you. If it's not green or yellow you've found your issue.
While you have it apart check you might as well check the condition of the o rings. Two inside the chamber, and a really thin one under the cap. Lightly grease them to 1) hold them in place and 2) provide a better seal and lubrication. That top o ring is a pain and likes to move out of place, be careful during reassembly that it doesn't get caught in the treads.
Old 05-17-2016, 08:00 PM
pvtryan478's Avatar
pvtryan478
After doing all that, which I'll do tomorrow, if it still doesn't make a difference, then what?
Old 05-18-2016, 04:17 AM
devilmotorsports
Cry, drink, or pray for divine intervention. Any or all of these, but after all that post here and we will try to help you figure it out.
Old 05-18-2016, 04:44 AM
pvtryan478's Avatar
pvtryan478
Okay, I'll check everything out after work today and post back when I figure something out.
Old 06-17-2016, 01:53 PM
64-bit's Avatar
64-bit
64-bit is offline
Just found this video, hopefully sounds the same way
Looking forward to install one on my CM
Old 12-03-2016, 09:09 PM
obdoesit's Avatar
obdoesit
obdoesit is offline
My forge recirc valve only came with the blue and red spring. I'm running manic stage 2 and went with the red because I push roughly 24psi out of the stock turbo. Do you think I should go to the blue one? I don't hear too much noise when getting off the throttle after a pull.
Those spring value's have me tripping out a little bit. Don't really feel like blowing out my turbo.
Old 12-05-2016, 10:58 AM
808keith's Avatar
808keith
808keith is offline
Aren't the recirc valve ones a lot more quiet than the atmospheric ones?
Cmv138
02-22-2016 01:45 PM
jpinkerton
02-19-2016 04:41 AM
themrethank
02-13-2016 05:10 AM
Naizur
02-12-2016 09:13 PM
Naizur
02-11-2016 11:20 PM
Quick Reply: R60 Blow off Valve
