R60 countryman all 4 rear driveshaft
I am doing a clutch change on mama' s 2011 countryman all 4 , 6 speed manual. Trying to remove driveshaft between trans and rear differential, have shaft loose at differential and hanger bearing loose. The front end has a large hex nut and a larger 12 point nut. Do I hold 12 point nut and spin the hex nut off?? or does it pry out like the front axles?? . I ordered a Bentley manual but would like to move on with project. Any help would be appreciated. Thanks, Dano
I found it on an ebay search , 97 bucks free shipping. My e-mail confirm said Voss motors inc and sales@books4cars.com on it. It was that yellow hard cover book , didn't say countryman on the cover but the description said it covered it. I was gonna buy one of them cd-roms but they said countryman was not on it. I hope I don't get the wrong one.
The Bentley Manual is for Cooper, Cooper S, JCW, Clubman, and Convertible.
888.280.7799 | 6am - 5pm PST
https://www.ecstuning.com/Search/Sit.../MINI_Bentley/
You can use it for the N18 or N16 engines and transmissions. But the All4 is not covered.
Where did you get it ?
this is where i got the manual
http://www.ebay.com/itm/310678423179?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
found it on ebay, the description said it was compatible with 226 models, including 2011 countryman all 4. if this book don't cover my car, I want one that does. Is there any such thing available????
Mini Cooper Shop Manual Service Repair Book 2007 2013 | eBay
Nothing for the Countryman yet, if the Bentley version one does come out , we will be the first to have to. You can use that one you bought for the Engine / non 4 wheel drive transmission parts.
dancooper
Sent you that diagram to help, but here is the All 4 :
http://www.realoem.com/bmw/enUS/part...ooper_SX&mg=27
http://www.realoem.com/bmw/enUS/show...diagId=26_0249
O yes sir I got the rear driveline loose from transfer case. I put a monsterous channel locks on the 12 point nut on the transfer case and a huge cresent wrench on the 6 point nut. It is backwards thread and was put on with loctite so some muscle was required.a heat gun may have helped a bit. The nut stays the transfer case it has some sort of flange on it. The drive line has male threads on it. Parts are on the way. Mama will be back on the road soon . That clutch job is a quite an undertaking.
Thanks for the diagram, I appreciate your help. I am getting a quite an education on this project. The next thing is to go after a P052B fault code camshaft position timing, cold start intake. The dealer was asking twentyfour hundred to fix that. I am going to search for some info on that now.
Welcome.
Thats all i have above.
For P052B
https://www.northamericanmotoring.co...2013-r56s.html
Also does anyone know the part number for the mini tool to remove the driveshaft nut?
rear driveshaft Countryman
I am in the process of taking my transfer case out due to a trans leak. When you say it's reverse threaded which way we're you looking at it? If I'm under the car looking towards the front I loosen the big nut clockwise?
Any update on the fix?
Richardpk82
R60 :: Countryman Talk (2010-2015)
12-22-2015 07:27 AM
