R59 Wear marks on Roadster top
#51
One wonders if some sort of bungee cord could be connected between the underlying supporting strap at the touching point and one of the frame members, in a way that in the top-folded position the cord would be under strain and pull the strap/top away from the rubber weather seal--while allowing the tension on the cord to be relaxed when the top was in the closed position.
to be continued...
#53
it just happens that I'm quite familiar with product design so I enjoy finding solutions to such problems . . . though admittedly time is the biggest issue...
#54
As I've said time and again, I became a lawyer by process of elimination. God gave me no other marketable talents.
#56
As I said in my earlier post; there was still contact after the replacement top was installed. New top material was less fuzzy in texture so I don't know if that will just delay evidence of wear marks or not.
I did cure the problem though. The 2012 Mini Cooper Roadster S convertible top wear marks are now the concern of someone else. The car has been replaced by a new 2014 Mazda Miata MX-5 power retractable hard top.
Enjoyed the Mini and may come back to one some day.
I hope Mini does get the problem corrected for you all.
#57
Some news...
I had my car at the dealer for regular service today, and asked them to replace the top. They called back later in the day telling me that there is a bulletin on this, and that they were ordering a top and frame. Should be here in a couple of weeks. I have a 2012 with a full manual top and I didn't get chance to ask if the bulletin applied to other years or to the semi-automatic top as well.
I'll update this thread as I have more news.
#58
Some news...
Need more details
#60
#62
#63
I'm a little nervous too, but they have been dealing with the regular convertible for years, and I have my original warranty plus their warranty on the repair work to fall back on in case of issues. I know others have had it done, and there's a tech bulletin which hopefully should detail the process, so fingers crossed...
#65
#67
#68
Having said that, in many cases if there's the right kind of bulletin on the defect you can often get work done outside the warranty period either free or at much reduced cost. We got a $2000 transmission repair on our Beetle that way. It's worth checking at the dealer that you go to for regular work and hopefully have a good relationship with.
#69
You've got to take quite a few detail pictures inside and out of the older one and of the new one once installed to see how different it is, how different it sits in, etc...
#70
It's at MINI right now being done, should get it back today/tomorrow.
#71
Sorry I should have been more clear. I was thinking overall pictures of the roof top, its frame, its fabric material, etc... to see if there is any sort of differences to any of the parts they are changing. But I wasn't very clear so it's my own fault
The reason is I'm not convinced they have changed any thing and they may just replace the top to keep y the customer, you in this case, happy. But I'd love to be wrong and know what they have change...
You can always probe them as to what changed exactly but I doubt they would know. Often the shops are pretty uninformed has to what the MINI UK engineers and designers are doing...
#72
I actually got a Roadster as my loaner, production date 11 2012 according to the sticker on the door jamb. It has the semi-automatic roof, and doesn't touch the seal when folded, so either the semi-automatic top is different, something changed between my build in Feb 2012 and this one in November of the same year, or some cars are worse than others...
#73
#74
More (non-)news...
They got two guys ready to pull the top off my car, and had two other guys open the box for the new top and were all ready to swap places when they figured out that the new top was for the semi-auto, not for the full manual like I have. They had ordered the part based on my VIN, but apparently something pulled up the wrong one. The correct one is supposed to be there on Friday so I'm in the loaner until then. More news as it comes in...
#75
More (non-)news...
