R59 Rear view Mirror covers
#26
Interestingly, the baseplate for the mirror (the part that attaches to the roof) is used on almost everything in the BMW family: E38/E65/E66 7-Series,E39 5-Series, E46 3-Series, E53 X5, E83 X3, E85/E86 Z4, of course R58 Coupe and R59 Roadster, and most interesting of all RR2/RR2N Drophead Convertible and RR3/RR3N Coupe. Those last two are the Rolls Royce Phantom Drophead (convertible) and Coupe! Something to tell your friends: "oh yes, and MINIs share parts with Rolls Royces, don't you know chaps!"
#27
Ok,
They do look the similar ( looked at this a while back before ), if they were exact , MINI would have based it on there fitment guide and would have added them. There must be something different. I will measure both and get back to you. And we have those covers and much much more.
F56 interior center mirror covers:
http://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Interior/Mirror/
Kuka822 - You are welcome, will post back here very soon.
Spiney and TG - There are allot of MINI parts and RR parts ( Rolls Royce ) shared from the BMW integration back in 2002+, spark plugs, hardware, electricals...etc. Also the supplier are very close to the factory's in England so they share allot more then one would think. That's why the MINI Goodwood ( Rolls Royce Bespoke parts ) edition was a bending of the two houses.
#29
#30
For the F56 Cover to R58 / R59 .
There are cover that are for *MINIs without autodip F56 51162353711
With Alarm tested on a R58 with Autodip ( electrochromatic dimming ) 51169219361 , 51169302885
The mirror 51162353711 to the round cutout is very close, does bulge out a bit. I would say its 90% a fit , top section would need pushed down ( where the U cut out is ) , it does come with 3M tape on the inside and prep wipes to adhere in the box. The other thing is there is light eye, its detect the light coming is about a small 3mm round dot on the passenger side of the mirror , it works with the auto dim to balance the dim by measuring the rear light photo sensor and the front light photo senor on that mirror. Covering it up might mess with the auto dim but I guess you could mark where it is and drill a hole. It very thin flexible plastic ( like a shell ). So I guess with some DIY work its possible.
With Alarm.
http://www.ecstuning.com/Search/SiteSearch/51162353711/
Like this model. I believe the manual mirror version is the same , just the round **** on the bottom is the flipper tilt for the mirror.
We did not take a pic. But that all the info I have.
51162353710 Black Jack Cover Rear-view Mirror
F56 MINIs without autodip & alarm. Did not even come close on the R58 with Autodip ( electrochromatic dimming ) 51169219361 , 51169302885 , its a bit less bulged and the bottom is square for the manual flip. Does not work at all.
http://www.ecstuning.com/Search/SiteSearch/51162353710/
Here is all the mirror covers :
You will want to look at the description you will need the alarm system mirror w/ that mirror if you want to try this DIY mod.
"Attaches to the back of the center mirror ; alarm system "
And then in the color cap you want.
Thanks and hope that helps.
See what you guys think.
With Alarm.
#31
Did you guys see the update. No one responded?
Just checking in.
Just checking in.
#34
Charile Victor - See post number 30 right above. Its very detailed. Since the r58/R59 does not have a factory cover option.
Cactusjk - there was a part split in 10/2012, R56 models 51162339377 10/2012+ chili red ( auto dip ) :::: 51162339378 10/2012+ chili red ( manual flip )
thanks
thanks
#35
So it sounds like the chili red manual rear view mirror covers for the 2013 R56 hardtop are now available in the US!
Charile Victor - See post number 30 right above. Its very detailed. Since the r58/R59 does not have a factory cover option. Cactusjk - there was a part split in 10/2012, R56 models 51162339377 10/2012+ chili red ( auto dip ) :::: 51162339378 10/2012+ chili red ( manual flip ) thanks
#37
Yea, we have its linked above.
12-23-2015 10:36 AM
dyeLucky
08-07-2015 07:10 AM
