R58 OEM MINI LED DRL's installed!
#26
#27
#28
Issue is the main wiring harness. if you don't have factory fogs you are missing the connections the kit plugs into and wiring to switch in the car. I have not seen a kit to install fogs on a non Factory fog install, it may exsist. You would need a kit for that or be prepared for allot of wiring. Anything can be done with time and $$$
#29
Help, I just purchased these with install from the dealer and they can't get the DRL to work. Only the position lights work. With headlights off, the DRL should make a full HALO. Dealer does not know why. They have them installed on their cars as well and same thing. While they continue to research this, does anyone know the trick to make these work right?
#30
#31
#32
It's worth saying again the DRL option in the Mini's set-up menu is asking you "Do you want to have the headlights permanently on as running lights?" and is not about using the LED DRLs - except that if you set the DRL menu option to 'on', the headlights will permanently be on and so the full circle of the LED DRLs will never come on.
So, DRL option off if you fit the Mini LED DRLs.
#33
#34
I don't know for sure if it's the same in the US, but here the parts warranty includes the labour for diagnosing and removing/replacing faulty parts, even if you just buy the parts and fit them yourself. That had me worried for a while, as that meant if the dealer could demonstrate it was my installation that caused the problem, then I would be liable for their labour charges. The warranty only applied if I took the car to the dealer with the faulty DRLs installed - there wasn't an option to return the faulty item alone and get that replaced.
#35
Yes, I agree. I set DRL to off, and still I get no full circle. It's just not right and even the dealer who installed cant figure it out. I think they have to program it in the codes. It's just funny that no one else seems to have this problem, but of the three that have been installed at my dealer, none of them work as advertised for us. 2 of the guys work at MINi dealer so I know they are motivated to find a solution. It just is a matter of time I guess until we all figure it out.
#36
I just had the Xenon Retrofit Headlights installed at the dealer on my 2014 Mini Cooper Coupe S and love how bright they are. Only problem is that they were not adjusted correctly and I had to readjust them today so that they fit in the hole in the hood and seat correctly. My Mini is going back in this week for the Retrofit Fog Lights. I wanted this combo when I purchased my Mini but the Coupe I purchased didn't have the Xenon Headlights and only had the regular Fog Lights. I didn't want to void warranty and was told that if the dealership installed them that they also would be covered in the original warranty of the car. Will post a picture later this week.
#37
The Headlights now also serve as turn signals. I'd say functional headlights. Let me know how you like them
#38
#39
#40
#41
Help! I'm having the same issue as Heathbar. I just had these installed by my dealer for $400 (installation only, not including parts) and the DRLs won't work. They cannot tell me why, and have suggested that perhaps these are for European models and the halo will never light for my US model. This just doesn't sound right.
The DRL is set to OFF on the stalk but I get nothing lighting up on the retrofits. I'm expecting the full halo. I get the brow when the parking lights are turned on, and the brow + fog lamp when the fog lights are turned on. So it's only the full halo that doesn't seem to be working. Did anyone figure out how to make them work?
Did anyone experiencing this issue use bmrguy03's fix regarding the blue and grey wire and get their full halos to light up?
#42
Help! I'm having the same issue as Heathbar. I just had these installed by my dealer for $400 (installation only, not including parts) and the DRLs won't work. They cannot tell me why, and have suggested that perhaps these are for European models and the halo will never light for my US model. This just doesn't sound right. The DRL is set to OFF on the stalk but I get nothing lighting up on the retrofits. I'm expecting the full halo. I get the brow when the parking lights are turned on, and the brow + fog lamp when the fog lights are turned on. So it's only the full halo that doesn't seem to be working. Did anyone figure out how to make them work? Did anyone experiencing this issue use bmrguy03's fix regarding the blue and grey wire and get their full halos to light up?
#43
Sounds like they spliced into the wrong wire. When I installed mine I tested them out without hooking up the blue wire and I experienced exactly what you are experiencing.
Make sure that they tapped into the correct connector.
There was some confusion about which connector when they first came out.
#44
+1 sounds like they spliced into the wrong wire.
#45
BTW.. it should be noted..
If you take to dealership to get installed, there is a hefty ECU upgrade they have to do and in turn all of your NCSExpert coding may be lost. I have VIM and quite a few other things coded and will let the group know if my settings are wiped w/the software update or not. hopefully not!!
#46
BTW.. it should be noted.. If you take to dealership to get installed, there is a hefty ECU upgrade they have to do and in turn all of your NCSExpert coding may be lost. I have VIM and quite a few other things coded and will let the group know if my settings are wiped w/the software update or not. hopefully not!!
#49
spiney, cerenkov, and ECSTuning: Y'all were right that something was wired wrong. My dealer contacted MINI, MINI provided a wiring diagram, and my dealer rewired my retrofits. Now the halos light up as the DRL. Thank you guys/gals! Weeeeee!!!! Monty's lookin so classy with his retrofit headlamps and DRLS!
jimmyselix:+1 to what spiney said. No coding was necessary for these DRLs except to set the DRL option to OFF on the turn signal stick. (The reverse of this video
#50
Great, glad you got them fixed and working now.
