Warning Light on speedometer !!
Old 07-22-2014, 04:12 PM
macadoo123's Avatar
macadoo123
macadoo123 is offline
The warning light that says my trunk or hood is open will not go off. I have double check but both are closed??
Old 07-22-2014, 04:40 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
What year car? Looks like a gen1 from the speedo pic....so a r52... So a 2005-2008?
If you checked everything guess it means a bad switch...have you looked at them to ensure they are plugged in and did not get wacked out of place? Hood one is on the passenger side front latch area if I recall...not sure about the others on the cabrio...
Old 07-22-2014, 05:26 PM
mdsbrain's Avatar
mdsbrain
mdsbrain is offline
Double-check if there is a solid connection to the locks of the boot and bonnet.
Old 07-24-2014, 01:37 PM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
You have a Gen 1 MINI, most likely an R52 Convertible
Looks like hood switch most of the time they pop out and the snap in breaks. Check both hood and truck.
Hood switch 61311480861 R50 R52 R53
https://www.northamericanmotoring.co...oose-wire.html
Trunk switch R52 Convertible. 61319119052
http://www.ecstuning.com/Search/61319119052/ES168350/
It goes in the bottom left hand corner of the rear trim part in this picture. When installed it points out and faces the trunk lid on the R52 Convertibles. Its the little rectangular cutout on the trim ( which also houses the convertible top rear parcel shelf detection sensor ).
http://www.ecstuning.com/Search/51466980045/ES119734/
And here is the forums you need for your post:
https://www.northamericanmotoring.co...2005-2008-152/
bneer
07-15-2019 04:41 PM
Lschneider
08-21-2015 02:21 AM
one73ronin
08-19-2015 12:36 PM
JamJam43087
08-16-2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
Quick Reply: Warning Light on speedometer !!
