R56 Best Wiper Blades?
Vendor
I've tried all the brands and the Piaa are the best. They do cost, but I've personally used them on my car for over 4yrs. They really work ask anyone that has had a set.
https://www.waymotorworks.com/piaa-w...-for-mini.html
I will +3 the Ikons I buy them for EVERYTHING I drive. 08 Mini,11 Ram, 03 Alero and will buy for the 99 Grand Cherokee! They cost about three times standard blades but out perform and last years longer.
No idea what wipers I have but they're one of the fancy sleek looking ones that are just a long thing of rubber, and I have the same exact problem. Drives me wild when I spray to clean my windshield and I see that little bit still dirty. Not a real problem by any means though.
I am happy using valeo.
I install a fresh set in winter and during summer time I install the old wipers. The sun is pretty aggressive in South Europe. By doing this, I keep the "fresh winter" blades for 3 or 4 years.
Ensure that you clay the windscreen every now and then, to remove dirt and pollutants that cause the irritating lines after using the wipers.
the secret to 'wiper efficiency' is clean glass. Most folks have no idea how much crud is stuck to the glass and will not come off with windex. Most folks DO appreciate that a clay job will greatly improve the paint finish by making everything very smooth by removing crud stuck to the paint but don't apply the lesson to the glass. I use a single edge window razor/window scraper on my glass at least annually and every time I get a bunch of junk off. Clay also works but you can be more aggressive with the glass as it is stronger than the paint! Many will save the clay they used on the paint and use this on the glass until next cycle. If my blades begin to drag or chatter, time for the razor to come out ... something is stuck to the glass. You still need to replace blades cuz they do wear out, and remember to CLEAN them when you wash the car, but even 'the best' blades won't work on dirty glass. Rainex etc and wax can mask the issue by providing lubrication over the gunk, but clean is better.
mountainhorse (03-10-2019)
What ^^ said. I spent 3 years in New England, I was in Boston winter of 2013 for literally their worst snowfall year in recorded history and the next year I was in Newport RI for it's worst snowfall year in recorded history.
For those who don't understand the concept of fluffy white **** falling from the sky it's not the snow that's problematic. It's the 100k tons of salt and sand those *******s put on the road to compensate for how ****ing shitty people drive in the snow. Wouldn't be a problem if stupid people weren't stupid...
anyways, sand, salt= replace wiper blades 10x more frequently than I would here in Seattle, where our wipers get used more than most places but typically only because water. I've tried everything found at the local box stores from the high end icons and whatever else 30+ a blade and all the way down to 7 bucks each because you know you'll be back to buy more in a month regardless.
So, depending on if salt and sand are an issue for you, buy the cheapest you can get and come spring time CLAY BAR your glass and get the PIAA's. Come winter, take OFF the PIAA's and get cheap *** blades. Come spring, clay bar the glass and REuse the PIAA's, cause they'll still be good.
If winter isn't much of a problem then clay bar your glass 1-2 times a year and rock the PIAA's until you need new ones. Which could easily be 2-5 years depending on climate.
