R56 Misfires in all four cylinders at once
Hi all,
I have a 2007 MCS auto trans, N14 engine. Yesterday I drove my car with absolutely no problems, it pulled like normal, ran like normal. We had a huge storm yesterday and I drove while it was pouring ran. My scoop is completely open to allow a little more airflow to the open box intake. Anyways, to the problem. I went to go drive it after the roads dried up and when I turned it on it was idling really rough. It kept surging from 800-1100 rpms. I started driving it and it had absolutely no power. It felt like I was driving with 2 cylinders. It would also make a deeper sound WOT. I got back home, and read the codes with my AP and it read that all four cylinders misfired. 5 codes total(I forget the actually codes)-
Multi cylinder misfire
Cylinder 1 misfire
Cylinder 2 misfire
Cylinder 3 misfire
Cylinder 4 misfire
Now I'm thinking its one of two things, but I don't have the money to do both. I'm thinking its either my ignition coils. Or I need an intake manifold carbon cleaning. I couldn't think of any other solutions.
If anyone on here could add some educated input or experiences that would be great. Thanks in advance.
Tyler
Cylinder 1 misfire
Cylinder 2 misfire
Cylinder 3 misfire
Cylinder 4 misfire
Tyler
Probably just from water getting down past your coils, much like dealerships and detail shops spraying down your engine bay with water will cause... If it went back to normal and doesn't happen again I wouldn't worry. Probably better to leave the scoop covered unless you have a ram intake that actually forces air onto your filter.. I had this issue with an old Mazda3 when I got water on my coil packs.
Reason I don't own it anymore is because it was only a Mazda3, not speed If I didn't get the MCS thats what I would have bought..
Tires, Wheels & Brakes
10-01-2015 10:38 AM
10-01-2015 10:17 AM
SneedSpeed
10-01-2015 03:01 AM
