R56 Brake sensors
If they didn't trigger the light but are worn then the estimated replacement mileage would be incorrect
Sent from my iPad using NAMotoring
People who check the pads/rotors constantly will tell you that they don't replace them, they just tie them up out of the way. For most folks it makes sense to spend the $20 or so to replace them. I always figure that if I sell the car, the next guy would benefit from getting a warning about the brakes.
If you trip the sensor then yes, if not and the sensor head are not bonded and rusted to the pad backing and you can get them out, they are reusable. One in the front left, one in the rear right.
If you do sell the car down the road the next person might not know if you do the tie back method.
http://www.ecstuning.com/Mini-2012-Cooper-R56-S-Coupe-L4_1.6L_N18B16A/Braking/Sensors/
The brake pad sensors are usable. Even though the sensor may be reused, they become brittle and do not always fit tightly into the new pads when reused. On MINI R56 models, the brake pad wear sensor has been updated. It is now more dedicated and prone to breaking when removed. The sensor is no longer a simple wire circuit that is broken when pad wear hits the minimum. It is now a two-stage wear sensor. This provides the vehicle with more accurate brake pad monitoring. So if the sensor shows the slightest bit of wear, replace it. We have a great DIY for brake pad sensor testing here (still relevant to your 2012 MCS), which provides the information I shared and more. But! Honestly, with the labor involved to get to them, set up a meter and all I would just replace the sensors if in doubt. If you have the time to test and would rather not replace, that's always your choice as well.
888.280.7799 | 6am - 5pm PST
Thanks for the update.
07-16-2020 12:54 PM
08-25-2015 09:18 AM
