R56 Lower Radiator Hose question
Yes, Its the lower hose and it has a leak at the clamp or the hose is split. 17122754223
http://www.ecstuning.com/Search/SiteSearch/17122754223/
There is little clamps that hold it into the lower core support so it will not hang down.
https://www.northamericanmotoring.co...-cooper-s.html
yes, its the lower hose and it has a leak at the clamp or the hose is split. 17122754223
http://www.ecstuning.com/search/sitesearch/17122754223/
there is little clamps that hold it into the lower core support so it will not hang down.
Corrosion on the turbo or coolant residue , looks like the stop plug /gasket for the turbo is leaking coolant just barley . Its so the turbo can be used with other car engines There is not part number for that part from MINI , but on the front side is the coolant lines. Wipe it off and see if it comes back or you can see dips. Car turbo looks pretty new, are under warranty ?
The washer from the front might work.
http://www.realoem.com/bmw/enUS/show...diagId=11_3946
http://www.ecstuning.com/Search/SiteSearch/07119963201/
Also you can have the dealership or yourself replace the height shield with updated version.
https://www.northamericanmotoring.co...-recall-3.html
#1 comes with clips. Looks like they lost it.
http://www.realoem.com/bmw/enUS/show...diagId=13_1212
There is no part number for that clip, this is the closest I could find. 51642755036
http://www.ecstuning.com/Search/SiteSearch/51642755036/
#2 hold the wire harness for later models who had the harness. I don't see any wire harness , unless they slid it under the intake and around the corner.
Before they added the additional harness, but has the clip.
#3 for the factory alarm sensor. Two piece in the bottom left corner of our pics
R56 9/2009+ , which then have to be installed and then flashed by MINI dealership.
http://www.ecstuning.com/Search/SiteSearch/65120443179/
[QUOTE=ECSTuning;4108199]Corrosion on the turbo or coolant residue , looks like the stop plug /gasket for the turbo is leaking coolant just barley . Its so the turbo can be used with other car engines There is not part number for that part from MINI , but on the front side is the coolant lines. Wipe it off and see if it comes back or you can see dips. Car turbo looks pretty new, are under warranty ?
UPDATE: (turbo - coolant residue) So far after one month that I cleaned these leaks residues off, it's still clean, I will keep an eye on it.
Thanks!
Thanks!
My mechanic tells me that the clams holding the hose up are fine and all its fastened properly, but still IT HANGS 1/4 lower than the bumper. Don't they make a shield for this hose, maybe something I can bolt on so when I scrape the bumper I don't scrape the hose?
Thanks!
Thanks for the order.
With a new clamp , it hangs a hair , but not too much. Check the clip in part also on the clamp.
https://www.northamericanmotoring.co...-rad-hose.html
Some people get the belly pan for extra hold up insurance.
Thank you so much!
silence2-38554
11-12-2015 09:39 AM
minipopkart
08-13-2015 05:22 AM
