R56 2008 valve cover question
So on the valve cover, this is a little plastic cap or something up on the right hand side of it.
What does that cover do and how do you remove it?
Looks like I have oil leaking from that part. I just changeed the valve cover gasket itself not too long ago but dealer is saying I have a leak which I don't believe the gasket is leaking just that little upper part.
and how the hell does it cost 1000 dollars to change the valve cover gasket yet it only cost 450 bucks to re-do an oil pan seal??
oh also...coolant gasket on oil filter housing... $1300 bucks!!!! god damn....
oil pan seal for $450? Find another place to do it. It only cost me $200 at a reputable SoCal shop.
Oil Filter Housing gasket for $1300 is mighty pricey, I know it can be done for at most, half that. I've done that for a few good friends now. It really is a PITA, but I'd never charge $1300 personally.
the oil seems to be coming from where they spring is where the diaphram is
http://s246.photobucket.com/user/ydd...a67af.jpg.html
looks liek there is a seal but I can't for the life of me figure out how to get that diaphragm cover off.
Ok. Now it makes sense. You don't get that cover off. You'd have to cut it off. The valve cover and PCV valve are all one unit. You have to replace the cover to replace the pcv valve system. I just replaced mine yesterday because of a leak. It cost me $313 in parts. Skip that $1000 quote. Thats rediculous. Unless they're replacing other parts too that they didn't explain.
I can replace the valve cover myself, I just did the seal not long ago. 300 dollar part.
If you can DIY it yourself you can save. Here the other parts linked.
N12 and N16 MINI Cooper 2007+ ( NON S ) you reuse the front cover part.
http://www.ecstuning.com/News/Mini_Cooper_Gen_2_R55_R56_R57_N12_Valve_Cover_2007 _2008_2009_2010/
on
Yea, it comes with new gasket set already on the cover. Just wanted to let you know.
But seriously, have you looked at the facilities these dealers are maintaining? They are enormous and totally upscale operations. My mini would blush if I drove it in there. Someone has to pay for that overhead.
09R56
11-16-2022 10:49 AM
Lex2008
08-16-2015 08:33 PM
