R56 Brake Pad Question
Vendor
The calipers are the same. The JCW ones are just red. The rotors and caliper brackets are what is different. So if you want to go to the larger rotors we actually put together a kit so you can convert to the JCW size rotors and use your stock calipers. The brake pads for the stock and JCW are also the same pads.
Rear R56 JCW rotor Conversion Kit
There is a spec thickness. It may be stamped into the edge of the rotor? If the rotor is at or below that thickness (measure it!) it should be replaced. If the friction surface is grooved (enough to catch a fingernail on) and the thickness is just above the spec, replace the rotors. Otherwise, have them turned (ground flat again) if doing so will leave them at or above the spec thickness.
Some people just replace them every time; I don't think that's necessary.
Can you recommend a brand of rotors that have treated you well for $40? The price of OEM rotors are pretty steep. Thanks.
07-16-2020 12:54 PM
