R56 So sad, need help guys.
I own a 2009 Mini Cooper S and when I went to a SMOG test ( I live in LA btw) and it failed due to smoke from the tail pipe. I tried to bring it to a mechanic and they say it is an engine problem. They suggested to put a No smoke/Stop Leak additive to the oil crankcase to minimize the smoke. They don't want to fix it and suggests to get a new engine. Should I try this additive or get a used engine instead for my Mini and how much an engine cost if I decided to get a new or used one?
Thanks for the reply. It is burning oil and sometimes I can smell it inside the car. I searched for the cause and it could be a blown gasket head. Btw it only has 68,000 miles. I had the thermostat replaced like 2 years ago which was the cause of the engine light before. I also had a hard time looking for a mechanic unless I bring it to the Mini dealer which is too expensive.
if its not overheating, and you don't have coolant and oil mixing in either of those fluids... i would not suspect blown head gasket. i would suspect you have either worn rings causing blow by (common problem, fix is a new engine), or carbon build up on the valves causing a bad seal and inefficient combustion (common $700 or so fix).
ask me how I know?
ask me how I know?
ask me how I know?
ask me how I know?
ask me how I know?
ask me how I know?
Additive
Greg
Yes that would help a lot. I just need to pass the smog so I can renew my registration and avoid late dues before I bring it to the shop. Can you please give me more info on this smokeless on?
Paying labor + machine time to strip an engine down, install new parts (lets face it, its an N14 you may as well do the timing chain/guide, completely clean all the valves and disassemble the head, update the water pump and valve covers to the newer designs, thermostat etc). you can save a few bucks by just doing a ring job sure, but are you saving any money and labor in the long run?
And sure, you can do a lot yourself, but judging from the OP starting this thread I am guessing they are in the "not DIY" camp. If you have to ask, you probably shouldn't attempt it right?
/ hijack. hopefully in the OP's case its just carbon buildup on the valves...but given the factor of oil consumption, I'm guessing it could be worse.
You say that the MINI dealer is too expensive but instead you would immediately follow some yokole's suggestion of a new engine. Go to the MINI dealer and ask for a proper diagnosis...
With the engine idling take off the oil filter cap turn it upside down it should just bounce around if it blows off bad rings and cylinders are probable also put your hand over the opening you should now feel a low but good suction. have an assistant rev to 2000rpm the suction should increase and level off. if the valve cover vacuum breather control is not working properly you will suck lots of oil but in most cases I think the engine will be toast by the time you know a turbo leak would be a good outcome a dealer rebuilt engine is about 3500 plus shipping etc. A swap is not a hard job if you have the right set up but it is a good job. Hmm its warm there and freezing here if you have a super nice garage and tools I might travel or I was looking for a spare n14 r56 to fix up.
This, or a failed PCV/valve cover both cause "oil burning".
Do you have any codes or engine lights?
I'd look into that before I poured a can of magic goop into the engine..
Ps - the magic cans of goop never fix anything..
Maybe this wasn't the case for the OP but I have a suggestion.
Since our cars tend to run fairly rich as designed by the manufacturer, ALWAYS make sure to drive your MINI for a while getting a smog test done.
Just driving a few blocks to a state inspection station for your appointment is not far/long enough for the engine and exhaust system ( cat ) to warm up to operating temps.
What the hell?? So because you have some smoke coming out of the car they are suggesting a NEW ENGINE??? Are you insane???
