R56 Need some Feedback prior to pulling the trigger on a couple Mods
on
So as most may know, I'm running the Manic Stage II +. All my current Mods listed in my Sig: CAI/FMIC/Res Delete IC Pipe/TBE, etc...
Well, first off Im getting some new tires. This is a must so I've decided to upgrade to 215/45/17 Non run flats. Should increase traction a bit
I have some extra tax refund money and I'm looking to get the following:
A) BSH Lower Engine Mount R56; Hoping to get more power to the wheels.
B) H-Sport Competition Rear Sway Bar; Not sure if this will be a little too much or just right when coupled with my JCW sports suspension (Dealer Installed).
C) www.howertonengineering.net/mini-cooper-tank-assembly, MINI Cooper Tank Assembly; Not exactly sure what this comes with. Does anyone know if I will have issues using this paired with my Snow Performance pump/Devils own hardware? Hoping it will be "Plug-n-Play".
I know some of these topics have been covered. I did my homework. I feel as though I peeked on the HP performance mods, unless I upgrade turbo. Not ready for that yet. So I figured dial in/tighten up the suspension, reduce motor slop.
Let me know if any of you have reached this point, and whether there is a better route or alternative solutions to what Im looking for.
The H-sport rear bar will be nice. It is adjustable, so you can tune it to what you like. I run mine in the middle setting.
There is lots of options for lower mounts, and just as many opinions on what people like. On my car (an auto, which can be more sensitive), I like the NM mount insert, but the Powerflex yellow had too much vibration at idle for my taste.
Have fun,
Mike
Have fun,
Mike
If you're going to get a complete replacement lower engine mount then the one from Colin is the way to go.
http://www.greeneperformance.com/col...6m-torque-link
on
I have the NM Large insert and the Powerflex press in small insert. That made a very pleasant change in the everyday driving feel. A lot less slop, a non-agressive accelerations are a lot smoother.
The H-Sport Comp. bar is awesome. I can't decide if this or my 215/45R17 Michelin Pilot Super Sport tires made the biggest difference in handling. Both both made a HUGE handling impact. I didn't have runflats before, but they were Eagle GT tires that came on the car when I bought them. Those were trash tires.
Obviously I would say do it all!!! But thats not always realistic. If you're going to get into autocross or drive a lot of twisties, the Swaybar is my vote. If your more of the street cruiser that may perform some rolling drags or something to that effect the BSH Mount is your better bet.
Keep in mind, I have seen a lot of people on the Marketplace sell their BSH mount because there was such a large increase in NVH.
I have the NM insert. Much cheaper than replacing the whole arm. I was worried about the increase in NVH so I stayed away from BSH, the one from Colin wasn't available yet. It would be nice to have a comparison between the two.
on
Yup, I have the BMS clutch stop. Not sure why anyone would not have this, LOL...
on
FYI, the NM insert installs in about 2 minutes (maybe less). Email Colin about his mount.
The company that makes it is known for making great engine mounts. They make the very popular ones that people use on the R53.
Call Howerton about the tank. He'll tell you exactly what you need to know.
on
Vendor
The Hsport Comp Sway bar and NM torque arm bushings are no brainers for the R56 as they are both best bang for the buck mods. I recommend them highly. The BSH mount is ok, but I'm not a big fan of the entire replacement mounts as NVH tends to be more likely with them.
We also have the powerflex torque arm insert which is a little more cost effective.
Howerton sells a Water - Methanol Injection system. His tank holds about a gallon of the WM mix, is designed to mount behind the rear seat, and the cap has the Mini logo. Your posts imply you want to use the tank for gasoline. Don't even think about it unless you're considering a WMI system, and then go for his HFS-4.
Hsport is an awesome swaybar --- really tightens things up. My NM torque arm inserts might be OK with a few extra HP, but they're useless with over 250WHP. Colin probably has the best one available, but I haven't tried it yet.
on
What are you looking for - handling, or HP? Seems like you've got the HP pretty well covered. If it is handling then get a stiffer RSB and some camber plates for up front, then an alignment for -1.5 to -2 deg of negative camber.
For tires, I'm really happy with my Michelin Pilot Super Sports.
+1 on the H-Sport rear bar. It's a no-compromise improvement. Actually, you do have to lube it about once a year, but otherwise no compromise. IMO, all of the replacement/insert dog bone mounts work equally as advertised. I don't like them for street cars because they do transmit quite a bit of vibrations to the cabin. That's just me, however, most everybody who installs them like them. Both the Colin mount and the BSH/Torque Solutions mounts are high-quality pieces. We just had a car come in the shop yesterday who ran over a street light post, damaging the undercarriage of the car. The car had a Colin mount which took a direct hit but didn't fail. It's pretty strong.
Thanks for the info. As for the tank, it's for Methanol not gas. I've been running the Snow Performance set up but tank crapped on me "got what I paid for". In saying that, rather than redoing a whole kit, I am looking at running the Howerton tank with my current hardware.
More about the tank --- options are baffles and lights. i tried to get both, but they weren't compatible with each other --- one or the other! I chose baffles, which are like hollow ping-pong ***** full of holes. Cuts tank capacity to about 3 quarts. You're gonna need a wiring diagram to connect it, and depending on where your old tank is located, maybe a lot of wire / tubing.
Features on the HFS-4 are great, and probably a lot more versatile than the Snow unit. You should consider "biting the bullet" and go for the complete system --- well worth the investment. Had mine since it was introduced in the "group buy" and haven't read or heard about any complaints on the system.
on
Like Cambo, I too didn't read your signature, and I've obviously forgotten about Snow Performance.
A new tank will allow me to take advantage of some awesome Stage II + performance benefits; Especially on Map C...
